Question about Lexmark T632 Laser Printer
Why is the printer grabbing more than one sheet at a time?
I don't know why this printer grabs more than one sheet of paper at a time. It only happens when I print more than one copy at a time. Please HELP, our warranty just expired.
    Master:
  • 461 Answers
Remove the paper tray and look at the pick rollers for and sign of damage or significant wear. These are not complicated or expensive to replace.
Posted on Jul 20, 2008
I have an HP copier (9110) and printer (4600). If the paper is curled or has been damp/wet then dried it will pick up several sheets periodically during a print/copy job. Once I got rid of the bad paper, it was o.k.
Posted on May 16, 2008
  • 26 Answers
Either you have a warn out paper pick up roller , or seperation pad.
wha'st the model of your printer?
and from were your problem is ( tray 1 manual , tray 2 casette ... ) ?
Posted on Jan 11, 2008
  • 64 Answers
This is caused due to the pickup rollers and seperation pads being worn. if you run your fingers across them you will no dobt find that they are very smooth and thats the problem. the rollers and pads need to be rough so that they can cause friction against eachother to seperate the pages. i
What make model is it and i will try source the part numbers for you
Hope this helps
Pete
Pete@wedotoners.com
Posted on Oct 10, 2007
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
PAPER WON'T FEED PROPERLY. GRABS SEVERAL SHEETS
You need a seperatin pad, sub pad kit and new feed roller.
May 20, 2010 | HP LaserJet 1100 Printer
My printer will not grab the paper
I have an R2400 and it is very finicky about grabbing the paper. I have to hand feed sheets of thick matte paper one at a time with just the right amount of pressure and even then sometimes it takes two tries. Make sure you keep the rollers very clean.
May 04, 2010 | Epson Stylus Photo R220 InkJet Printer
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Canon R265 keeps grabbing 6 sheets for printing one sheet
Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
Jun 15, 2009 | Epson Stylus R265 InkJet Photo Printer
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Lexmark T632 Laser Printer Logo
454 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
