Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
HP F1903 turns itself off when connecting DVI
The monitor will turn on and work fine with a VGA input, but when connecting it with DVI it will turn itself off. This is the second (F1903) monitor to do this, the first was a warranty return. I have switched both video cards and DVI Cables. I appreciate any help/advice that can be offered.
  • Kravitz Feb 27, 2008
    Twenty seconds after I turn on my computer, my monitor goes black. I know it's not the hard drive, because older monitors work with my tower. I've also swaped out the cables and power cords, same results. This thing is only 2 eas old and it would cost A LOT of money to replace, I am pissed.... no more HP for me. Any suggestions?
    Scholar:
  • 116 Answers
Sounds like your problem is hardware and lies with the port on your PC, this may be due to a bad driver, or bad port! Sounds like you have tried everything else!
Posted on Nov 26, 2007
HP L1950 DISPLAY MESSAGE NO DVI INPUT
in this situation, there are two options. 1.The device connected to your TV via DVI cable is off. 2. DVI cable connected to the HP L1950 is burned.
if you try to connect a device to the HP L1950, it has two ways to connect:
Input Signal - Two connectors: one 15-pin mini D-sub analog VGA and one DVI-D. Try VGA them.
Apr 06, 2014 | HP L1950 Monitor
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
I moved and lost the video cable to my HP Pavilion F1903 monitor where can I get a new one
Any "male-male" video-cable will work.
Check whether you need a VGA-to-VGA cable, or a DVI-to-DVI cable, depending on the connectors (oval for VGA, rectangular for DVI) on both your monitor and your computer's video-card.
Try the local "Thrift Shop" (Salvation Army, Value Village, et cetera).
Try any local computer-store.
Try any "big-box" store (BestBuy, Walmart, Staples, OfficeDepot, FutureShop).
Try 'www.ebay.ca'.
Nov 18, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
F1903 not turning on with tower when restarting
Get a PCI or VGA video Card!
I'd recommend at least somethin like a
nVidia GeForce 7300 GT (256mb) Video Card
You can get one for dirt cheap on Newegg.com
Or your local PC store/Repair shop.
The Problem you are having is your Video Card Driver isn't the correct one, or it's got issues...
You should get a better video card.....yours might be onboard or really low-end rated.
FYI -
Pre-Manufactured PCs generally ****..... I build WAY better PCs for less.
HPs ****, but not as bad as a Dell (Dell does make the best pre mf 'd Servers which is ironic!)
but the worst pre mf'd PC I've ever fixed was a GATEWAY........
Apr 19, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Display input
You have to make sure the dvi connection is turned on.
Jan 03, 2008 | LG Flatron L1810B 18.1" LCD Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
118 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
