Question about Panasonic AG-DVX100 Mini DV Digital Camcorder
DVX-100A PSD NG error message
Help! My boyfriend, a DP, is on a shoot right now in Boston and his DVX 100A is showing this error message -- PSD NG. I think it's an image stabilization issue. He says the picture is "vibrating." My question -- is there any way he can shoot with this camera right now and still get a good picture? Thanks. lisa
  • georgetlr Mar 05, 2008
    I've the same problem
  • cineclipse May 11, 2010
    does anyone know what the problem is when you get the message auto lock on the screen--it has happened when i am shooting, as well as on playback
I think there is something worn in the lens.
I just give the the camera one or two sharp smacks with the heel of my hand
beneath the front body of the camera (not the lens),
That clears it up.
You can probably turn the stablization off too, but I think you also lose some display info.
Posted on May 06, 2009
SOURCE:
How to resolve the problem with psd file?
If the file is corrupted, there's nothing you can do short of finding another copy of the file.
Sep 27, 2016 | Computers & Internet
A message comes up when I try to open a file in Gimp, when I haven't had issues opening it previously.
You may repair .psd files with the aid of
fix corrupt psd file
program can't modifying your original .psd file data during restoration
Feb 17, 2012 | GIMP GNU Image Manipulation Program
Hallo,i am in malang/indonesia i have a problem with my dvx 102b.on the lcd screen theres a warning:PSD NG....what can i do?maybe you can help me to solve the problem,thankfulll for any help
PLease reset your camera then restart and try.
If not success then please visit service center.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Panasonic AG-DVX102AE DV Digital Camcorder
PSD Warning Panasonic DVX 102A
I can help you with this.Disassemble the right side which includes the lcd display,so you can see the lens unit.Use a blower to blow air inside and point it to the lens.Better if you can remove the lens unit and blow air on it with caution and then assemble it back the problem disappears.
PS
If problem insists remove ccd block and apply inside a small amount of grease on the metal axis inside ois coil which is used for moving coil mechanism for optical stabiliser purposes.CAUTION THIS ONLY IF NO RESALTS WITH THE ABOVE METHOD.GOOD LUCK!
Nov 04, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
PSD NG
Hello! You need to disassmble the side which includes the lcd monitor, so you can see the lens and ccd block area. Blow air inside to clean the parts,and reassemble it .If the problem continues please let me know.There's another way then.
Apr 01, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Showing warning psd ng in dvx102 panasonic video cam
PSD NG means that there is a problem with your electronic image stabilization system.I think Panasonic got stuck with a bad batch of gyros. Take it back if you can, otherwise use lower resolution or hold very still when filming.
Mar 26, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Warning message
PSD NG is an error dealing with the OIS [optical image stabilization]. It can be fixed, it is not as terminal an error as many have rumored it to be. The caps could be a cause, but very remotely THE cause. You can have the camera sent in to Pani, and they will fix it, and you will get a bill for $300 - $600.
However the main cause for so many of the dvx100 series to have the psd ng error is loose cables. If you feel sure of your self with a screwdriver, tweezers, & forceps, you can make the repair yourself. In simple terms, all you need to do is reseat the ribbon cables. Follow the steps & photos here:
http://www.dvxuser.com/V6/showthread.php?t=172290
I did this repair with great success. It was a nerve wracking two hours, but I have not had the error reappear since. I got the camera from someone dirt cheap, [read 1/4 value], because of the psd ng error. I made the repair & not only have a fully operational unit with beautiful pictures, but I also quadrupled the value of it.
Apr 24, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Panasonic AG-DVX100 Mini DV Digital Camcorder Logo
796 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
