The most common problem is that there is a chunk of debris stuck in the small pump that feeds waste water into the rubber hose drain line. Remove the lower front panel on the dishwasher to get to the drain pump. Take it all apart and take a look. Remove the debris and reassemble everytning
Comments:
Apr 30, 2009
- The most common problem is that there is a chunk of debris stuck in the small pump that feeds waste water into the rubber hose drain line. Remove the lower front panel on the dishwasher to get to the drain pump. Take it all apart and take a look. Remove the debris and reassemble everytning
My Kenmore model# 665.15817990 dishwasher has not worked as more than a dryer rack for the better...
(More)
My Kenmore model# 665.15817990 dishwasher has not worked as more than a dryer rack for the better part of a year. The drain function works. But no washing cycles work. I am able to select the 'pots/pans' mode, the 'normal wash' mode, and the 'quick rinse' mode, but when I do the 'water heat' and 'no heat dry' functions turn on as well for about 4 seconds. Then the 'control lock' function turns on for about 4 seconds and then the 'no heat dry' function turns back on. This 'no heat dry' to 'control lock' cycle continues indefinetaly. From this point nothing happens until I press the cancel key and the control goes blank. It might be worth noting that as long as there is power to the machine two of the wash indicator lights and two of the rinse indicator lights remain on very dimly. I'm sorry if this description was too lengthy, but I assume more information is more helpful to one who might like to help me. Thank you for taking the time to read this and, if able to, for helping me figure this out. Again; thank you.
The pots and pans light flashes and the dishwasher won't start. The cancel button has no affect. The...
(More)
The pots and pans light flashes and the dishwasher won't start. The cancel button has no affect. The digital display shows --. I unplugged the unit and after plugging it back in, there was a 2 in the display and after a short while it went back to the -- and the pots and pans light started flashing again. Any ideas wiuld be appreciated. Thanks
