Question about Panasonic KX-FL501 Plain Paper Laser Fax
All of a sudden my drum unit/fax machine has started making a noise
Hi, All of a sudden (since yesterday) my drum unit/fax machine has started making a rubbing noise (as if two wheels inside the fax machine are colliding with each other while rolling). It sounds like drum unit becoz when I take out the drum unit the noise disappears, and when put it back in the noise again starts when I close the cover. Also, the noise appears when any fax is printing, the paper gets jammed too after that noise. Please help me and tell me what should I do. I have tried cleaning it several times, check paper jams, but nothing helped so far. Please reply back asap. Thanks. Regards, Arpita
  • 31 Answers
Ask for replacement to your supplier if you think that the drum causes the problem.
thanks
Posted on Mar 11, 2008
Take off the  two side cover, watch the gear rolling while printing you will find the noise come from, might be one of the gear is broken, certified technician will do the same thing when they troubleshoot the problem too, good luck
Posted on Dec 13, 2007
Intermittent printing problems
It sounds like the drum unit has a really dirty charge wire. Toner gets on it and hardens and will start arcing, causing blank copies. Try replacing the drum unit
Mar 20, 2014 | Brother IntelliFax-4100e Fax
Makes grinding noise when starting to print
Remove the drum unit (and toner) shake it gently from side to side to make sure toner inside is evenly distributed...
Reinstall and try that
Oct 26, 2009 | Brother IntelliFAX 4100 Laser Fax
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Loud Clicking Noise
CHECK ON EBAY FOR REPLACEMENT DRUMS OR LOOK FOR A NEW MACHINE,
Feb 09, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
IntelliFax 4100 suddenly slow to print
If the dial tone sounds NOISY or SCRATCHY there probably is a phone line problem. Try changing the phone cord first. Are you using DSL phone service?
You have a very reliable fax machine.
Nov 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Recieving fax error
It could be a bad drum unit. If the drum doesnt turn smoothly it will make a clicking or grinding noise since it is gear driven. Take out the drum and turn the gear with your thumb. turm towards you. If difficult Thats it. It also could be a fuser gear. good luck Lawrence
Apr 22, 2008 | Brother IntelliFax-2820 Laser Fax
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Panasonic KX-FL501 Plain Paper Laser Fax Logo
383 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
