Question about Bounty Hunter Land Star Digital Metal Detector with Ground Trac Re-Tune - LSTAR w/FREE UPS
Will not detect
Turns on with fresh batteries and does the usual series of beeps. All the buttons work and the settings can be changed but does not detect anything at all on any setting.
  • 60 Answers
It sounds like you could have a bad coil if you know of anyone with a Bounty Hunter detector than just try swapping out the coils and see if it takes care of the problem. If you need to you can order a new coil from the manufacturer or on eBay. If this is not the problem than you should contact the factory (First Texas Products) about repairing it. If it is less than 5 years old they will repair it for FREE, even if you are not sure how old it is they have no serial numbers on their products so they can not tell how old they are so they will still repair it for free if you tell them it is less than 5 yrs old. Call them first before sending it in, 915-633-8354
I hope this helps, Dutch
Posted on Nov 11, 2009
  • 3,051 Answers
Have you contacted the tesoro dealer in prescot arizona they are working on mine come to find out i had a wire inside that was broken please keep me posted ok best regards and happy findings mike
Posted on Aug 16, 2008
SOURCE:
Need to reset projector to factory default settings
hold the power button until it beeps or turns on ect but keep holding it and it should reset
Dec 07, 2013 | Acer X1261P - DLP projector - 3D - 2700...
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
My camera has a "lens error". It will not contract back and stays out in zoom...it beeps and gives me this message to start, but doesn't do anything.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera.
Thank you !!
Jun 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
When i turn it on the screen is just black
when ps3 is in standby (red light on) hold down power button you will here the ps3 beep once and turn on then it will be a 2nd time. as soon as it beeps a 2nd time release the power button. This should re detect your tv.
This usually happens when changing from a/v to hdmi or vice versa.
Hope ths helps
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
Camera wont turn on
The camera may in fact be hung in voice recording mode, or may in fact have a low voltage error or internal failure. Suggest that you follow this routine. 1 remove batteries and press the on button, nothing should happen. Allow camera to sit for five minutes. 2 remove memory card if one is installed into camera. 3 install two fresh batteries in camera and attempt to power it on. 4. once on set the time and date. attempt to take a photo. then cycle the camera off. Once again power it on and see if the settings remain intact. If it is working then power off and insert the memory card and test again. I have found that allowing the camera batteries to run low and die in the camera cause a series of problems like the one that you have. Always use rechargable batteries of the Nickel metal hydride construction in this camera. This is the only known reliable power source for this camera. Note: camera instructions for this model can not be found on the samsungusa site and you will have to go to http://www.samsungcamera.com to find instructions for this older model.
Jan 27, 2008 | Samsung Digimax D53 Digital Camera
Don't work.
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just set the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
It really doesn't matter if you'll be using 2500mAh. So long as those are the recommended batteries, those will work.
Jan 03, 2008 | Samsung Digimax S630 Digital Camera
Weird problem. Camedia d-520 doesn't turn on. Blinks and Beeps.
I'm having the same problem with mine. Happens on rechargeables or brand new standard batteries as well. Very frustrating. I can't take more than 2 videos in a row without the dreaded orange/green lights flashing (low battery warning). Leaving it for 10-20 minutes and it works again, with the battery charge showing full.
Aug 14, 2006 | Olympus Camedia D-520 Zoom Digital Camera
Bounty Hunter Land Star Digital Metal Detector with Ground Trac Re-Tune - LSTAR w/FREE UPS Logo
138 people viewed this question
Top Bounty Hunter Optics Experts
Marvin
Marvin
james laughton
james laughton
Are you a Bounty Hunter Optic Expert? Answer questions, earn points and help others
