Question about Belkin (F6C800-UNV-PL) UPS System
Belkin F6C800UNVPL UPS does not auto start
I am having a problem with these UPS's not starting up automatically after the power comes on. The unit runs the battery out during the outage, but when power is restored I have to manually turn it back on. Is there a way to have it come on automatcially upon power restoration? Thanks.
    Habit-Forming:
  • 188 Answers
U have problem with ur automatic utility....
contact ur dealer or go to any ups shop.....
they will fix it in a very cheap cost man....dont forget to tell me u r problem solved or not
best regards & best of luck
Posted on Oct 13, 2007
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 05, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..& IF U R PROBLEM IS SOLVED RATE MY SOLUTION AS SOLVED
    best regards & best of luck..
SOURCE:
Belkin battery backup bu3dc000-12v alarms
Hi Mike,
Electronic circuit issue,
you have to repair unit or replace the circuit bord.
regards,
nuwan.
Jan 11, 2014 | Power-Sonic Belkin 84Whr BU3DC000-12V UPS...
Sir, My PC is starting problem, 1.Starting UPS - ON the system starts automatically without swith ON. 2.After Starting the keyboard & Mouse get stuck 3.after Restart the the keyboard & Mouse...
The UPS may not be sufficiently stable on power-on to run a PC immediately.
Try going into the BIOS setup after the restart and look for the option that has the computer "Start up automatically after power failure." Turn this off. That will take care of problem 1.
If this also takes care of problem 2, you may want to check whether the UPS has a problem. Start by plugging a couple of lamps with 100 Watt bulbs into the UPS outlets instead of the computer. Turn it on - the lamps should behave normally, not flicker or change brightness. With the lamps and UPS still on, unplug the UPS. The lamps should stay on with little or no change, and the battery warning light should not come on right away. If the UPS fails this test, its battery may need to be replaced or it has a regulator problem.
Apr 08, 2011 | Intel DG965RY Motherboard
What doies it mean if the unit turns itself off, resulting in a loss of power to my electronics?
Most likely your battery is dead in the UPS. Replace the battery if you can. Belkin should be able to help you with that.
Mar 14, 2011 | Belkin 900VA ( F6C900-UNV ) UPS System
Hi! Per our UPS problem is when open 3 or 4 hours, then auto Off the UPS. please let me know what the problem. And i need to change the PCB board or just repair the PCB board? Thanks Regards
If you unplug the unit and it powers your PC for 3 or 4 hours then turns off, it is because the batteries are empty and this is normal. If it is plugged-in with power and shuts itself off after a few hours, then the battery cells may be in need of replacing. You can purcase an inexpensive replacement battery here: http://www.upsforless.com/browseproducts/Powercom-Replacement-Battery-Kit-BNT-500A-BNT-500AP-BNT-600AP-BNT-800AP-KIN-425CSU-KIN-625CS.HTML
Dec 01, 2010 | Powercom BNT-600AP (bnt600ap) UPS System
Belkin F6C1500-TW-RK discharged new batteries, won't recharge
This sounds like a battery issue...I would have the unit and batteries tested at your nearest batteriesplus store... www.batteriesplus.com
May 07, 2010 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
My Belkin 550VA don't start up The model is F6C550-AVR
this may happen because of gone battery without battery it will not comes on mains also so directly change battery before that you also check the fuse if blown replace it with same ratings problem will be solved
Feb 24, 2010 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
Only my UPS goes down!
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts You need a 1000VA UPS. The one you have is way too small.
That 375 UPS is good for answering machines, plus it does not have AVR technology. Your UPS power supply is 250Watts, and the monitor is at least 150 watts and the printer is another 200 watts....=600watts
So that 375VA ups x.778= 291.75 watts. That hardware of yours is killing your very very very cheap UPS. It is obvious that Tech support has no application engineering support. Well I did all the work for them.
I suggest a 1000VA or a 1500VA for more time.
check out my web page, I only sell to dealers, but I will help you out.
www.storminprotection.com
May 21, 2008 | Belkin (f6h375-usb) UPS System
Belkin F6H650-USB
If you did not take a lighting hit everything should be OK. Plug a light or another electircal device in to make sure each socket works. If not you have a problem I recommend to replace UPS. Your UPS should show a low battery LED. Here is a link for your manual for your model UPS. If you need any more help let me know?
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/f6h-ser-user%20manual.pdf
Jan 02, 2008 | Belkin Home Office UPS System
My model FC6120-unv is dead
If you've got nothing my guess is its something more than the battery as it should still be able to draw power if its plugged in. If its within the warranty period (3 yrs, I believe). Go to the belkin webpage and to their ups support and start the process to return it and get it fixed/replaced. A couple months ago I had a F6C500-UNV that suddenly died on me just like yours - no nothing. It cost me $13.00 or so bucks to ship the broken unit to Belkin; a week or two later I got a brand spankin' new F6C550 or whatever they currently sell in that same voltage area back from them. The cost to RMA the broken unit was much cheaper than even buying a new battery for the old and now discontinued unit.
Dec 26, 2007 | Belkin ( F6C500-UNV) (Bundle)...
Belkin (F6C800-UNV-PL) UPS System Logo
136 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
