Question about Toshiba TDP P5 Multimedia Projector
Toshiba TDP-P5 projector
The projector is hooked to a PC in a conference room. It starts up and gets to where we see what we want to see, but then after about 5 minutes it shuts down and does that everytime. Appreciate any help...... thanks
  • 5,603 Answers
Possibky is overheating... I would put a fan on it and see if the time-to-fail changes,
Posted on Jan 10, 2010
SOURCE:
Gets hot shuts down its toshiba TDP-SP1 how can i resolve it?? do i need to change cooler?
Make sure filters are cleaned. Use a vacuum so you don't spread dust around inside your projector. Make sure the projector can "breathe"; has room around it.
Nov 04, 2013 | Toshiba Office Equipment & Supplies
I installed wireless utility for TDP TW95 toshiba data projector in windows 7. but it is not connecting properly. It says valid adaptor not found
hook it up with the USB cable so that you can hook up the Projector to your network. then you will be able to find it.
Jul 04, 2011 | Toshiba TDP-TW95 DLP Projector
In my toshiba TDP5 P5 I have a lamp with 1200 to display, but since yesterday the lamp does not ignite, indicator blinks green fast. According to instuction explanation "the fans will cool down and...
You are correct with the diagnosis. If the power supply is OK then you should hear the high voltage that strikes the lamp giving a sharp 'crack' noise like a spark in the spark plug of a car as it tries to ignite the lamp. If you can't hear it, then the lamp may be OK and the Ballast board is faulty
Feb 26, 2011 | Toshiba TDP P5 Multimedia Projector
Toshiba TDP-P5, used unit. Startup image comes up ok. When PC is hooked up, the image does does not change from startup. Cables test okay on other projectors, the video port on the PC is working ok on with...
Try pushing the source/select button to make the projector look for a source. It is the button that looks like a bent arrow right in the middle of the 4 arrow buttons.
Jan 14, 2011 | Toshiba TDP P5 Multimedia Projector
I am looking for a hardware that will allow me to install Toshiba TDP-T45 on ceiling.
you can get a universal ceiling mount from pc world or online at toshiba get any toshiba.
Feb 05, 2010 | Toshiba TDP-T45U DLP Projector
We have a Toshiba TPB P5 projector that displays all menus, and shows the computer display fine at first, but as soon as the video changes (new page, new window) the projector shuts off and goes to...
First check your video with ANOTHER external monitor. It may be the video output of the computer turns off (It often comes from a different driver than the main computer screen). This would then be a software problem...
Jan 09, 2010 | Toshiba TDP P5 Multimedia Projector
Toshiba TDP-SP1 Data Projector Pink Tint
go into menu and make sure input is computer and not rgb component. or just reset to factory defaults.
Jul 30, 2009 | Toshiba TDP-SP1 DLP Projector
My projector makes a really annoying noise
It is also possible that the bearing is going bad on the fan. I'd look into getting a replacement fan if that's the case. It is probably cheaper than a replacement bulb that would be needed if the fan failed entirely.
Jul 09, 2009 | Toshiba TDP-P5 DLP Projector
Toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Dec 29, 2007 | Toshiba TDP-S8U Multimedia Projector
Toshiba TDP P5 Multimedia Projector Logo
138 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
