Question about Kenmore 22422 Top Load Washer
I also need the answer...
I have a kenmore 80 series, top loader, 3spd motor, ultra rinse, heavy duty, super capacity plus, quiet pak "The washer does not drain the water out after the wash cycle. It started a month ago not spinning the water out enough but now it simply doesn't do it at all. This is weird to me because I can put the washer on the regular wash cycle and it works. It won't release the water or spin out after the wash cycle. Any help you can give me I really appreciate. I'm stuck with a washer full of water." Please help
  • 2 more comments
  • Anonymous May 13, 2008
    where is the lid switch on a top load kemore washer
  • rikk274 Oct 16, 2008
    I've determined that the lid switch is the problem. Can you tell me the best way to revmove the cover for the machine? I've pulled it forward to release it from the clip but the rear section is still holding strong.
  • Anonymous Dec 11, 2008
    My washer will not drain. It goes through the cycles just fine but when it comes time to drain between cycles it just sits there! Any ideas?
  • Maria Vazquez
    Maria Vazquez Sep 09, 2014
    I live in the 55 plus and need an answer.
  • 447 Answers
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Posted on Oct 03, 2007
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from
Hope This Helps,
Mar 12, 2009 | Kenmore Washing Machines
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
432 people viewed this question
Sal De
 Brian Main
Brian Main
