- Answer is very general. No specifics, like what parts to replaced, where to get them, how to install them, or how to go about fixing the problem.
May 02, 2009
- Thanks for your answer. You are right. I have no intention to atttempt to fix it myself. I just wanted to know what has to be done. Your input has been very helpful.
The convergence output ic's must be replaced and some solder rework on associated connectors.
Comments:
May 01, 2009
- Aw specifics huh. Well the convergence output ic's are STK-392-570. And check solder on connectors VG and VR. Just google the part number and you can order them online. As to the question about how to change them. If you have to ask that you should probably not attempt this repair on your own. Each output has 10-12 pins and must be desoldered to be removed.
I have a mitsubishi WS-55809 and the format on standard setting seems to be on zoom? how do i adjust...
(More)
I have a mitsubishi WS-55809 and the format on standard setting seems to be on zoom? how do i adjust the screen?
Error Code Probable Cause 12 No error detected The green light blinks once then twice meaning I have...
(More)
Error Code Probable Cause 12 No error detected The green light blinks once then twice meaning I have no errors. So why won't my WS 55511 TV come on?
I have a 2004 Mitsubishi HD1080 Series 60'' widescreen, model WS-65315. I purchased a new Insignia...
(More)
I have a 2004 Mitsubishi HD1080 Series 60'' widescreen, model WS-65315. I purchased a new Insignia surrond sound amp, mode lNS-R5101HP.I cant get the menu, for the amp,to show up on the tv. I am using HDMI cables, with an adapter for the DVI on the tv. I also have connected a Dish Network sattelite recvr and a PS3 wich both showed a picture thru the rcvr to the TV, but no sound.
