Question about Jet 3 Ultra Power Chair
Need to remove the bad batteries Jet 3 power chair
I need to replace the batteries in my Jet 3 the 2 in there are not holding the charge up.How do I get to them? does the seat have to come off?
  • 3 Answers
Hello Donald ,
You may have solved this problem by now ,but just in case you have not, here goes.
Make sure the chair is turned off and engauged in the drive mode meaning not in the free wheeling mode. This way it will not roll around on you during the battery change out.
Go to the rear of the chair and slightly turn the two black plastic lock pins,one on each side they actually lock the small )) shaped cover in place. Turn these with your fingers or you can also insert a dime in the slot on top of each pin to turn them . You will be able to tell when they have unlocked as the )) shaped cover will be loose. Lift the cover up and under it you will find the battery connector, unplug it and leave the cover off for now.
Next ,move to the front of the chair and just to the rear of the footplate you will find a locking pin that runs through the lower rear bar of the footplate as well as the chair frame itself . Pull this pin completely out. Once done you should be able to pull the entire footplate assembly out torward you, Black plastic front cover included. Once you have it pulled outward lift it upward and it should lift completely off the chair. This done , you should actually be looking at the front battery which is sitting in a black plastic tray. Gently but with a firm grip grab the tray anyplace you can and slowy begin to slide it out from under the chair torward you taking care not to tangle the battery connector at the rear with any other wiring on its way out. Once you have the tray slid out into the open ,you will be looking at both batteries after which you will need to unhook the straps that secure the Batteries to the tray after which you will need grab your wrenches and remove the battery harness itself from each battery. You may want to do just one battery at a time this way you'll have less wiring to keep track of when wiring in the new Batteries. The Batteries in your Jet 3 are a size known as U-1 deep cycle sealed maint. free batts, You can use either Gel Cell or seale3d LA replacements . Though they are much cheaper, you cannot use lawn tractor batteries. Though they look the same the internal technology between medical powered mobility batteries and tractor batteries are entirely different. The latter would only run your chair for maybe a half hour or so before needing charge.
Take great care to make sure your wiring hookups are correct and that you position the rear connector plug to the rear of the tray. This way you will be able to locate it easier once you have slid the tray back in under the chair and it is time to go to the rear of the chair and reconnect that plug. As for everything else ,reattach it in reverse of the way you removed it including remembering to slide the lockpin back into the front footplate frame. Give a tug on the footplate when done to make sure it is locked and secure.
In closing I offer this valuable advice : When working with any of these batteries, always were safety glasses or goggle and gloves (terminals are lead). I also advise removal of metal rings ,watches, bracelets etc that could create a short when reaching in and around the battery terminal. Take great care with your tools and wrenches in making sure you keep and eye on both ends of the tools at all times. This way you will not accidentally cross the posts of the battery. Take your time ,use proper safety technique and you'll do fine. The following is Pride Mobility's step by step for battery change out and is basically the same as I have sent . Can never have to much info but can always find yourself with not enough. Take Care
To replace the batteries:
1. Turn off the power to the controller.
2. Make sure that the power chair is in drive mode. See III. "Your Power Chair."
3. Turn the rear shroud fasteners one-quarter turn in any direction. See figure 6.
4. Remove the rear shroud.
5. Unplug the battery connector. See figure 26.
6. Remove the retaining pin from the foot platform and lift the platform up and away from the power base. See figure 19.
7. Slide the battery tray forward.
8. Unfasten the reusable strap around the front battery.
9. Disconnect the wiring harness from the front battery.
10. Remove the front battery.
11. Unfasten the reusable strap around the rear battery.
12. Disconnect the wiring harness from the rear battery.
13. Remove the rear battery.
14. Place a new rear battery on the battery tray. Make sure that the terminals are facing forward.
15. Fasten the reusable strap around the rear battery.
16. Connect the wiring harnesses to the rear battery.
Posted on May 14, 2009
    New Friend:
Can I hook my jazzy 3 to 220 volt power when travelinf
Posted on Jun 23, 2014
I can't find the battery connector?
Posted on Jul 03, 2009
SOURCE:
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
I have a Jet 3 power chair. I recently had 2 new motors and batteries installed. I am having problems with the batteries holding a charge. I charge them every night for 10+ hrs. It shows full charge in the...
yes there is a short either in the motors or joystick u would be better off contacting the dealer and have a tech run his programmer on it and tell u what is wrong, will save u money if u can take that power chair to the dealers shop
Jan 21, 2014 | Jet 3 Ultra Power Chair
I cant get my power chair jet 3 to charge batteries are good
Hi valentin 201
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. . In the future give as much info about the scooter as possible.
1. load test the batteries even if you think they are good, check anyway. Sometimes even new batteries won't hold a charge.
2. Your charger on the powerchair must have enough volts to open the charger inhibitor. That is, the charger won't even start up if your batteries are low. Both batteries need to have at least 20-22 vdc.
3. Some chargers have a 3amp fuse check that and repace if needed.
4. With a multi meter set on dc200 check your batteries. Red on one battery and black on the other. Check to see what you get for voltage. If no voltage reverse the lead wire to the other posts. Once you get a reading of 20+ volts watch the meter and plug in the charger, it should increase the volts on the meter. if not the charger is bad, replace. Charger should be 24-31 volts to be a good charger.)
One of these sugestions will fix the problem
Good Luck
Tim
May 03, 2011 | Jet 3 Ultra Power Chair
Charges but only holds a charge for about 1/2 hr running time. the manual i have says it has a external charger but mine is onboard. thanks ---- wayne
Wayne if you are getting a full charge and then only getting that little running time its time to replace the batteries. If Medicare paid for your chair then they will pay for most of the repair costs.. Contact the provider where you got your chair to ask about new batteries or you can get them yourself for about $200.00+ for both. You will need to get 2 U1 deep cycle batteries. Do not get unsealed or auto batteries for your chair get U1s Hope this helps
Apr 16, 2011 | Jet 3 Ultra Power Chair
Jet 3 will not turn on but when you plug charger cord in it will light up the entire length of the battery indicator when you push the switch. Chair will still not move. Controller is a PG Drives Pilot...
the batteries are not charged and need to be replaced. The reason you have lights is because the charger is supplying power to the chair and the chair will not move when the charger is plugged in because of the inhibit function. Replace the batteries and make sure you charge before use Hope this helps
Apr 15, 2011 | Pride Used Mobility Jet 3 Power Wheel...
My mom has a Jet 3 Ultra and by reading other comments it sounds like we need a new battery, so I have 2 questions: 1 - where do we buy the battery 2 - how do we replace/install the battery - can we...
Did Medicare pay for Mom's chair? If they did then they will pay for 80% the repair to the chair. You can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 they are both excellent repair companies and will schedule a tech to pick up mom's chair leave a loaner and fix the chair for her. Now if Mom bought her chair then she will have to pay for the batteries and all other repairs needed (lets hope not). The chair needs 2 U1 sealed batteries and they can be purchased through the provider where she got the chair or at any good battery outlet like Interstate Battery. I would avoid Internet stores because of the shipping costs. Do not get them from Wal Mart or any other chain store because they do not sell sealed deep cycle batteries required for your chair. The batteries will cost you around $200.00 for both. The provider will probably charge you more. You have to unplug the joystick cable, remove the seat from the base and take the shroud off the base and there you will see the 2 batteries. Remove the wiring harness and remove the batteries reinstall the new batteries wiring them like the old ones, replace the shroud and the seat hook up the joystick cable push the on/off switch and pray that it comes on (lol). The old batteries can be recycled through any battery dealer in your area Hope this helps. If you have any questions you can reach me @ lennieg2000@yahoo.com
Mar 15, 2011 | Jet 3 Ultra Power Chair
I just purchased a used Jet 3 ultra power wheelchair...after charging it up I turn it on and the red light is flashing and it makes like a clicking sound when i try to make it go forward..cand you please...
bobby
The batteries are not charged. The red light indicates low batteries and the clicking sound you hear is the electric brakes being energized. Now the problem could be bad batteries or a bad charger. If you have access to an off-board charger (maybe a friend or acquaintance might have one) plug it into the charger port located under the front of the joystick. Don't plug in the on-board charger at the same time. Charge the chair overnight with the off-board charger and you should see a red light(power) and a green light(if the chairgot fully charged) if the light is still yellow then the batteries are bad and need to be replaced. Your chair uses 2 U1 batteries and if there is a battery store near you get them there. Interstate makes a good battery if you have a dealer near you. Hope this helps Good Luck
Oct 22, 2010 | Jet 3 Ultra Power Chair
The chair has not been used in over a year now and we have been charging it for 24 hours now and it still has no charge. What should i do?
The batteries are too low for the charger to pick up. You need to replace the batteries This chair takes 2 U1 batteries. Hopr this helps
Aug 24, 2010 | Jet 3 Ultra Power Chair
The battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Jun 08, 2009 | Pride Mobility Products New Pride Mobility...
Jet 3 Ultra Power Chair Logo
5,006 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
