Question about Compaq Armada M700 Notebook
M700 wont boot
After trying to uninstall windows disk came to a file it could not read I removed disk and every since after startup will locks up with remove disk or media message,to continue press any key,pressing key does nothing,there is no disk in drive.
  • 457 Answers
What windows were you trying to uninstall what are you going to install in its place?. You know if your trying to install XP then just install you have to partitian and format NTFS is the best but you can use FAT. You cannot go anywhere at present because you interupted the las can go no where.
Posted on Oct 04, 2007
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
A boot disk (startup disk) and why you need it?
The Windows installation disc contains the files necessary to start Windows, so it is itself a boot disk. A boot disk is actually not a computer disk in the shape of a boot. If it was, most disk drives would have a difficult time reading it. Instead, a boot disk is a disk that a computer can start up or "boot" from. If a problem is preventing Windows from starting, you can use the installation CD to start Windows. The installation CD also contains Startup Repair, which you can use to repair Windows if a problem prevents it from starting correctly. Startup Repair can automatically fix many of the problems that in the past required a boot disk to fix.
A boot disk (sometimes called a startup disk) is a type of removable media, such as a floppy disk or a CD, that contains startup files that your computer can use to start Windows. CD and DVD boot disks are often used to start up a computer when the operating system on the internal hard drive won't load.The startup files are also stored on your computer's hard disk, but if those startup files become damaged, you can use the files on a boot disk to start Windows
Earlier operating systems that used the FAT or FAT32 file systems, such as Windows 95 and Windows 98, a boot disk was especially useful because it allowed a person to access files on a hard disk even if Windows was unable to start. This ability also represented a security risk, because anyone with a boot disk and access to the computer could start the computer and access any file. Hard disks formatted with NTFS have built-in security features that prevent using a boot disk to access files..
Let looks at some useful "boot CD downloads" to create one for Windows OS,s.
1-Ultimate Boot CD for Windows - This BartPE-based boot disc comes with a huge selection of tools to access your data and get your PC booting properly again. Some of them are even useful.UBCD takes a long time to load and asks you some odd questions before it's finally up. But once it's there, you can edit the Windows Registry (yes, the one on the hard drive) in RegEdit, recover deleted files, and even run benchmarks. setting up UBCD is identical to creating a BartPE disc--with the same possibility of failure. But when it works, you get a lot more.Price: Free
Download Ultimate Boot CD for Windows.
2-Puppy Linux - A third party application to create a boot CD using Linux and great for accessing NTFS-formatted hard drives--especially if you're not comfortable with Linux's whole mount concept. Just open the Drives window and select a drive, and Puppy will mount it for you--in read/write mode, if possible.Puppy will mounting the drive with read/write permissions and you not only can copy your files elsewhere, but you can also edit them. Puppy Linux comes with AbiWord, which supports .doc files, and Gnumeric, which supports .xls. And even if it mounts read-only, you can still copy the files to an external drive, most of which are formatted in the universally accessible FAT32 file system.
But be careful how you click. Actions that take double-clicks in Windows, such as opening a file, take only one in Puppy.
Price: Free
Download Puppy Linux.
3-BartPE - The BartPE operating system makes a pretty good boot disc on its own, getting you into Windows and letting you access your drive. It doesn't have much in the way of repair utilities, but it has chkdsk, which should probably be the first one you try.To create a CD, the program needs the Windows 2000 or XP installation files. One place you're sure to find them is an actual Windows installation CD-ROM. But the recovery disc that came with your PC probably doesn't have them.
Luckily, if your PC came with XP installed (and thus, not with a true XP CD), the necessary files are probably in a folder called C:\Windows\i386. But I do mean probably, not definitely. However, since the PE Builder is free, you're not losing much if it can't create a disc.
Price: Free
Download BartPE.
4-Vista Recovery Disc - a unique distribution of Microsoft's own recovery tools.This Recovery Disc is basically a Vista installation disc minus the install files. It even has an "Install now" button that asks for a Product Key before failing. You're better off clicking the Repair your computer button. Among its Vista-only options are a tool for diagnosing and fixing startup problems, a version of System Restore that uses restore points on the hard drive, the restore portions of Vista's backup program, and a memory diagnostic tool. Price: Free
Download Vista Recovery Disc.
5-Trinity Rescue Kit - TRK's command line interface could humble anyone but the most devoted Linux geek.
If you take the time to read the 46-page documentation and learn the program, you'll be rewarded next time disaster strikes. Among the tools that will be at your disposal are a script that runs 4 different malware scanners, a tool for resetting passwords, a Registry editor, a program that clones an NTFS partition to another PC over a network, a mass undeleter that tries to recover every deleted file on the drive, several tools for recovering data off a formatted or dying disk, two tools for fixing master boot record repair programs, and hardware diagnostics.
Price: Free
Download Trinity Rescue Kit.
Hope that you understand the benefits of having a boot disk on your wardrobe.
on Jan 04, 2011 | Computers & Internet
She gets an error message when booting up:: Fail to load language file
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Go to Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but only when you initiate.
If this fails, even though this should fix it, download CCleaner (free) and clean your Windows Registry.
Oct 05, 2012 | Acer Aspire Computers & Internet
My system is hanging.what can i do?
Try going to the task manager to check if you have too many processes running on the background that may be consuming resources. You can open it by pressing the Ctl+Alt+Del keys on your keyboard at the same time.
May 09, 2011 | Computers & Internet
Hi everyone, I would just like to know, does anyone know how I can obtain or create an emergency boot up disk for windows xp home edition? Many thanks. Andrew
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
Jan 15, 2010 | Computers & Internet
Armada m700 working fine. oneday got message 1782 disk controller failure. have tried removing things. will get message even if hard drive & caddy removed. have reset startup sequence have tried with...
 disk controller failure - the chip from the laptop's motherboard that's controlling the disks is fried. Nothing you can do - all hd's will be unrecognized - that laptop is dead.
 Buy a new one.
Oct 30, 2009 | Compaq Armada M700 Notebook
Message read/ missing export user 32.dll update layerd window.
To resolve this issue, follow these steps:
  1. Restart your computer using the Windows 98 or Windows Me Startup disk.
  2. On the Startup menu, choose the correct CD-ROM support for your computer.
  3. Type the following commands, pressing ENTER after each command:
    cd <windows>\system
    ren user32.dll user32.dlx
    ren gdi32.dll gdi32.dlx
    ren winmm.dll winmm.dlx
    where <windows> is the name of your Windows folder and <ramdrive> is the virtual drive created by the boot disk (probably e:\ or f:\).
  4. Type the following line, and then press ENTER: For Windows 98:
    <CD-ROM drive>:\win98
    For Windows Me:
    <CD-ROM drive>:\win9xwhere <CD-ROM drive> is the drive letter assigned to your CD-ROM drive. Note that this letter may be different when you boot your computer with the Windows Startup disk.
  5. Type the following line, and then press ENTER:
    user32.dll gdi32.dll winmm.dll
  6. Type the following line, and then press ENTER:
    where <drive> is the drive on which Windows is installed, and <windows> is the folder containing Windows.
  7. Review the information displayed. If it is correct, press Y.
  8. Type the following commands, pressing ENTER after each command: cd
    ren Cmapieng.vxd Cmapieng.vxx
  9. Restart your computer.
  10. Once Windows has restarted, run the Defragmentation application.
When Ext.exe has finished extracting the files, follow these steps:
  1. Remove the Windows 98/Me Startup disk, and then restart your computer.
  2. Press and hold down the CTRL key as your computer restarts. On the Windows 98 Startup menu, select Safe Mode.
  3. After Windows starts, on the toolbar click Start, point to Settings, click Control Panel, and then double-click Add/Remove Programs.
  4. On the Install/Uninstall tab, click any utility that you have installed, and then click Add/Remove to remove the utility. Repeat this step to remove any utilities you have installed.
  5. On the toolbar click Start, point to Settings, and then click Taskbar And Start menu.
  6. Click the Start Menu Programs tab, and then click Remove.
  7. Double-click Startup, click the appropriate entry, and then click Remove.
  8. Click Close, click OK, and then restart your computer.
  10. In Microsoft System Information, on the Tools menu, click System File.
  11. Click Settings, on the Advanced tab, click Restore Defaults, and then click OK.
  12. Restart your computer.
Sep 20, 2009 | Microsoft Windows 98 for PC
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Registry problem
You know how to get to the safe mode option. Well get to that screen and try last known good configuration. What this does it takes restores everything up to where you last logged on your computer successfully. If that doesn't work run the windows disk, delete the partition and start fresh. If that is a no go you have a hardware problem most likely.
Jan 01, 2009 | Compaq Armada M700 Notebook
Compaq armada m700 wont boot up
most of this kind of problem are located in a corrupt file or a bad sector on the hard drive that checkdisk won't repair you got two option to try. one make a backup of you files and reinstall the Operating sistem or try to fix the surface of the hard drive with an utility call "HDD regenerator" in the 70% of the cases I had it fix the problem specially in older notebooks whitout the need of reintall the OS. you will try and may be this fix your problem. (tihis utility comes in a disk called "Hiren"s" boot cd.)
Jul 18, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
