Question about Denon AVR-2106 Receiver
Denon set up -
When I want to listen to am\fm stereo all I get is a very low audio when I crank the volume all the way up. What would cause this? I have been through the set up numerous times and even set everything back to factory with a reset...
  • 979 Answers
Check your tape monitor settings and make sure that you don't have "monitor" selected without having a processor of sorts connected to that respective monitor...accordianman
Posted on Oct 25, 2007
Denon problems
I'm not familiar with your unit. However, go to systems surround set up and turn up volume for those surround speakers you speak of.
Mar 22, 2014 | Audio Players & Recorders
Denon AVR 1609 Receiver circuit breaker trips repeatedly
Probably the output stage(s) short circuit at peak volume levels, causing the breaker to trip.
Mar 21, 2017 | Audio Players & Recorders
I have a kenwood KDC-MP245 , AM /FM/CD car audio player . When I crank up the volume the unit shuts down for a few seconds then comes back on . It continues to do this until I lower the volume , then it...
Depending on the vehicle this radio is installed in, the impedence from speaker must match the stereo as well as the resistance. If you are using factory speakers in a vehicle some are as low as 1 ohm which will cause a short in the stereo. This will cause the radio to shut off. You need to check the specs of the radio to be sure. If you need more help with this please let me know.
Sep 08, 2011 | Car Audio & Video
My AG-V3050 pro-logic receiver seems to have a volume control issue. The test mode volume works fine but when I switch it to fm the sound is very weak, I have to crank it all the way up to get a little...
Hi
Two dump question and than recommendation..
  • First ;During listening FM ,Your " MUTE" switch is "ON" or "OFF" ? if not how about plain STEREO mode ? did you try it ?
  • Second..how about the other Modes , i.e ..CD ,DVD etc. ? same problem or it happens only in FM ?
ok..now the possible solution;
sometimes FM stations do not properly triggers pro-logic circuit and cause such problem and you need to switch to STEREO or A.F.D mode to listen FM (AFM includes sub woofer)..
This is true for FM only and it should not happen in other modes as DVD ,CD,Phone etc..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 29, 2011 | Teac AG-V3050 Receiver
Purchased used.For trial purposes I only hooked up a few speakers. Only get a little sound when its cranked up on stereo FM. Does it have to have all speakers hooked up to work? I tried to get sound in a...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-689-Receivers-manual/id/23110dj894/t/2/
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Feb 26, 2011 | Denon AVR-689 Receiver
I have a Denon Receiver, that recently started having volume problems. after listen to any source for about 40min to an hour, the volume either totally cuts out or increases to max volume. This condition...
The control section seems to have a thermal problem, when its cold it works, then warms up(metals expand with heat) it loses a connection. Can be either a solder connection or a component, these are found with freeze spray by a qualified technician.
Nov 15, 2010 | Denon AVR-2805 Receiver
Auxiliary too quiet when using my iPod!
clean all conects with acohol and cheak for shorts
Jul 08, 2010 | Pioneer DEH-P7700MP CD Player
The volume on the left channel on my old (20+ yrs) Denon stereo receiver is too low intermittently, usually until it warms up from use, and sometimes after. Ideas?
Problems of this nature are often caused by electrolytic coupling capacitors. If you have access to an audio signal generator. Inject signal at volume control and compare left and right output levels. This will isolate fault to pre amp stage or power output stage. freezer can be very usefull in isolating this type of fault.
Feb 27, 2010 | Denon DRA-455 Receiver
DRA-345R stereo receiver. FM is gone, poof! just like that. nothing looks burned. where do I start? No change to the antennae has been made
I have a denon DRA-345R and when I put on position mode cd I can listen music and then after 1 minute the mode change automaticly to position FM. Tell me please what a have to do?
Jan 31, 2010 | Denon Audio Players & Recorders
97 Jeep Grand Cherokee Limited Stereo problem
If you still have audio but unable to turn the volume, there are 02 possible problem:
- the volume control is defected will not respond ( electronic volume control; need logic low/high to activate the audio )
- the front control PCB is broken ( can be fixed if there is a small cracked )
If no audio at all then most likely audio output IC defected
Dec 19, 2007 | Cherokee (REF) AM/FM Stereo with CD Player...
Denon AVR-2106 Receiver Logo
104 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
