Question about Jenn-Air JSD2488G Side by Side Refrigerator
Ice Dispenser - in door
Our Ice machine is making ice, however when we go to dispense the ice through the door, it is not coming through the flap (the ice dispenses into the slot, but does not come through the flap into the cup. I was told there is a "solenoid" in the door that controls the flap to allow the ice to come through. Does anyone know what that part # is for this model, and how to fix it? Or is this something that needs to be repaired by a professional?
  • 1 more comment
  • greenbanani Oct 03, 2007
    Great! Thank you for the quick response. I've ordered the fountain door kit and hopefully the problem will be solved! Thanks again.
  • greenbanani Oct 04, 2007
    I'll be happy to change the rating to Solved once we receive the part and actually fix the problem.
  • greenbanani Oct 05, 2007
    The part arrived yesterday. Your solution was exactly right and we were able to fix the problem ourselves! Thank you so much. I will definately use this site again!
  • 447 Answers
Yes that repair is quite common and not too difficult you need a Maytag Fountain door Kit dont have the part# hear but can be researched available at all appliance part retailers........comes with the solonoid, new flapper door and outher redesigned pieces also an instrunction sheet A solved rating is great motivation to continue giving priceless advise........
Posted on Oct 03, 2007
  • 1 more comment
  • joey  shearer
    joey shearer Oct 03, 2007
    a solved rating would be greatly appreciated
  • joey  shearer
    joey shearer Oct 04, 2007
    Solved is meant for when your question has been answered properly not necessarily when the unit has been repaired. (Plus will guarantee i will keep the answers coming)
  • joey  shearer
    joey shearer Oct 05, 2007
    Im very happy you appreciate what we at Fixya can offer the public. I hope we can be of service again!!!
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Mf12568aeb lights flashing and ice door flapping
You will have to call Maytag at 1-800-688-9900...Motherboard is bad. You can pull out the little plate at the bottom of the water/ice dispenser, then unscrew the two screw. Pull on the bottom and the panel should come out. Unplug the white connector on the left. This will stop the flapping of the ice dispenser flap.
Sep 23, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice dispenser freezes
check your ice dispenser door flap,is it coming all the way down?there is a solinard that opens and closes it,it might be going bad,if you can get in to it it might just need alittle lube,what make?let me know what you find-mike
Oct 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Left freezer door open ice melted, now machine makes ice dispenses water but won't dispense ice.
THE PROBLEM MIGHT BE WITH YOU ICE DISPENSER MOTOR.TRY TAKING THE ICE DRAW OUT.CLOSE THE DOOR AND PUSH THE ICE FLAP IN THE FRONT OF THE DOOR.IF YOU DONOT HEAR A LOAD NOISE THATS A INDICATION THAT THE MOTOR IS NOT WORKINK.LET ME NO IF YOU REQUIRE FUTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 18, 2008 | Whirlpool Refrigerators
LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Nov 30, 2007 | LG LRFC25750 Refrigerator French Door
Jenn-Air JSD2488G Side by Side Refrigerator Logo
580 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
