Question about HP LaserJet 1100 Printer
Hp 1100 printer problem
When i print something that is more than one page, it prints over top the previous page. doesn't matter if its 2 pages or more, it will print onto one page. any suggestions to fix this or is it time for a new printer? thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Two possibilities, one the seperation pad is going bad so it's feeding the other paper too soon or the clutch is slipping. most likely the sep pad take a look doesit look really smooth and shiny? try cleaning with alcool or sanding with a very mild sandpaper to take away it's smoothness. Should work for awhile.
Posted on Oct 11, 2007
SOURCE:
I have an HP LaserJet1020 printer. When I try to print a document a 2 inch wide area the full length of the page on the right side of the page) will not print. If I change to landscape printing, the same...
Run the 1/2 print test.
Print a few pages that have failed previously and as the printer is printing open the cartridge cover(top cover).
Pull out the cartridge and look at the paper down below. If the page looks good, you probably need a new fuser. If the page is messed up you could have a bad transfer roller or another bad toner cartridge.
Dec 19, 2010 | HP Office Equipment & Supplies
My laserjet 1150 is printing multiple-page documents all on 1 page -- in other words, page 2 and 3 print over the top of page 1 -- i've removed and reinstalled the printer and driver from the original...
try to download new drivers from the HP site.If that doesn`t help you than means you forrmater board has been damaged and you need to buy a new one.
Nov 01, 2010 | HP LaserJet 1150 Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Because my Deskjet 932C wasn't printing at all, I downloaded a new driver for it from the HP site. Now it prints but prints only the top portion of a page -- sometimes about 1.5 inches, sometimes 3 inches,...
I would recommend uninstalling the installed driver from your system, disconnect the USB cable (if one is installed), reboot.
Once the system comes back up, turn off your anti-virus. Now install the printer driver again. Install the USB cable for the printer (if that's how you're connecting) and finish the install.
Re-enable your anti-virus.
Aug 29, 2009 | Office Equipment & Supplies
HP Laserjet 1100 - prints test page text & image on envelopes
try to uninstall the drivers and reinstall them it should fix it
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | HP LaserJet 1100 Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Hp printer 1100: new cartridges: print very light
I apologize for the delay in responding to your inquiry. I have researched this matter for a number of hours, and then typed a fairly lengthy solution. For some reason, just before it was to be posted it disappeared. (We have to love these PC's, right?)
There are approximately a dozen specific models of the 1100. As you haven't indicated any specifics asde from 1100, and based on your description, I have worked with the understanding that the machine is an 1100. Most often, light printing is caused by issues with the cartridge, drum, or photosensors, as relevant, in addition to printer parts not being clean. These matters become nearly mute points, however, as you have indicated that the printing of the test page was approprate. It is important to remember, though, that when you put a new cartridge in, the toner should be distributed evenly by shaking gently left to right / side to side.
There are driver updates available for this model. Assuming an OS of XP, please see http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14925&prodTypeId=18972&prodSeriesId=25470&swLang=8&taskId=135&swEnvOID=228.
The last point & print bundle prior to this, on the product-specific page, was dated in 2002. Reference: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14925&prodTypeId=18972&prodSeriesId=25470&swLang=8&taskId=135&swEnvOID=228.
On this same page, you will find two tools at the top which could be quite helpful in evaluating the problem with your printer, under "Useful Links" - check to see if you need updated drivers on your system, and the second to help you locate the proper driver.
Have you atttempted to print either (1) from another application on the same PC or (2) by attaching the printer to another PC to test the print in this manner? Finally, "Fast" or "Economode" is a printing method which uses less ink and prints more quickly, however, it also then generally results in lighter output than a normal or fine print. Test pages are typically printed in fine mode, It would be fruitful to make sure that the printing preferences are set to normal or fine rather than economode, due to the need to determine the actual reason for your problem. I would also add that the problem appears to be between the printer and the PC, rather than strictly with the printer, given the status of the test page. Testing the printer with another PC may be one of the most valuable troubleshooting steps, and if there is still a problem, please switch the USB port, and the USB cable, with which the printer is communicating, in order to further eliminate these issues.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 14, 2008 | HP LaserJet 1100 Printer
All pages going in at a time
u need to take it to a HP repair service, or if u can open it and replace the separation pad arm tat is located in the printer.
Apr 22, 2007 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
52 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
