Question about NEC Dterm DTP 16D-1 Corded Phone
Nec dterm80 How do I remove the DND from my phone? Is there a code for it or something. There used to be a button but since we added lines it was removed. Any help would be greatly appreciated. Thanks
  • alma439 Feb 04, 2009
    My phone "seems to be set on DND" I have a NEC Dterm 80.It goes straight to voicemail. When I try Feature 69 Feature it just gives me a dial tone. When try Feature 42 Feature it just shows a number "2" and when I pressmenu-program-Cancel- it doens't fix it. Can anyone help???
    New Friend:
  • 18 Answers
Another solution is to pick up on intercom and dial 4 then 2 and hang up. That is the default DND cancel code. It can be used form single line phones within the system as well.
Posted on Jan 25, 2012
    New Friend:
Press Feature then hit 69 then hit Feature again. Everyone on here that said this forgot to hit Feature a 2nd time.
Posted on Jun 14, 2010
  • SMouk Aug 09, 2013
    This worked for me! It ahs been a month...but this is what did it. THanks!
My display is nearly unreadable. It has blue bars over the display.
Posted on Jun 17, 2008
How do i get the dnd off the phone
Posted on Sep 24, 2009
Press feature then 69 this eliminates the DND!!!
Posted on May 20, 2009
To get rid of the DND you have to press Feature 69 Feature.
Hope that helps!
Posted on Mar 12, 2008
I think you select from buttons at top of phone, "Prog", "DND", "Cncl"
Posted on Oct 24, 2007
SOURCE:
DND on Nec phone not working. I still get the calls in
Likely the button your pushing is just a speeddial button with the DND code, which somehow has been erased. Don't know which of the 12 or more NEC systems u have, but someone should have the user guide to reprogram.
Apr 20, 2016 | NEC Lands Phones
How do I take off do not disturb
If you have a DTP-16D phone, I believe that device was used primarily on the NEAX 2000 system by NEC. If that is true, you can try the default DND cancel code: #8 (*8 sets it). Unfortunately, the system codes CAN be changed by the installer, so it could be something else. Please let us know if that works. Thanks.
Sep 18, 2015 | NEC Dterm DTP 16D-1 Corded Phone
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
DND causing line to go busy when on call for new incoming callers
Please contact your local NEC dealer and have them program the phone to go to voicemail when in DND or when Busy
Mar 20, 2009 | NEC-1090021 DSX 34-Button Backlit Display...
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Nec dterm80 light flashing green
For the green light, you can turn it off from DSS. On the bottom left hand side of DSS, it is a message button. You can press the button and then your extension button. The green light will go away from the DSS and on your phone. I hope this helps.
Mar 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
6,788 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Norman Al-Anbar
ray gallant
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
