I have a problem with my Printer. Iv only used black ink. I ********** use black only, and after using all of my black ink, all my other colours seemed to become lowered. I want to just buy black ink only, but I don't know why the other colours get used up even tho iv never used the ink.
Why does all the other colours get used up?
The epson like many other brands actually uses a small amount of the coloured ink in order to give the black print a more polished look.
You must use your printers properties page to set printing mode to Greyscale if you don't want it to use the colours.
To do this go into your control panel, open the printers icon, and select your printer, right-click on it and select Properties from the grey menu.
You will have to look through the pages and find the setting or check box for Grayscale. When you find it, select it, then click ok at the bottom of the page. This will stop the printer from using coloured inks to tone the black print.
Hope this helps FixYa,
Chris
Try this link, about 1/2 way down there are instructions to get into your advanced options menu, I found Grayscale hiding in there. It was hidden a bit worse than most.
http://files.support.epson.com/htmldocs/...
This should finally do the trick for you.
Chris
Iv tried finding Grayscale by checking through all the properties from my printer drivers, but I've found nothing. Is there any other solutions?
