FixYa.com
Tags:
Tappan TGFS_63 Gas Kitchen Range
Range burners (by 9 users)
posted by tiffrain26 on Oct 03, 2007
All four burners on my oven just started igniting over and over. It's making the noise when the knobs are turned to lite and you can see the spark on all four. It won't stop and all knobs are turned to off. It just happened out of no where I wasn't even using it. I turned the fuse off for now and I left it off over night and it still did it today.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by caninekid, posted on Mar 26, 2008
I have the same problem, ticking noise when I turn gas burners on that never stop ticking... I pulled electrical plug from outlet and lite with a match. How can I stop the ticking
Comment by sorceress, posted on Jan 17, 2008
I've had the same problem with this stove for years, I have had it repaired 4 times, they have replaced the computer each time and the problem went away for a while. I do no think they ever replaced a switch. I have found that turning the burner on briefly, seems to work to get them to turn off until they decide to go off again. I have noticed if one of the knobs is pushed in too far it seems to cause it also. Strangely my stove ususally does this either after I 've been cooking all day- " a holiday", or late at night- between 4 and 4:30 am- I would hear it trying to start- making the clicking noise. One repairman indicated it might be that there is greese or oil that is making an electrical conection- I could see that with all day cooking but that doesn't go with it starting late at night. It happened again last night- This Sat. we are buying a new stove- I have had it. My family has always thought it was haunted- glad to know it has happened to others too.
Comment by ovenmadness, posted on Dec 22, 2007
same problem... what is the solution?
Comment by FrankenFly, posted on Dec 12, 2007
What kind of meter is it? How do I identify the specific switch with problem? Do I replace the switch?
Comment by Guest, posted on Nov 29, 2007
The electric ignitor "clicks" at constant intervals. I have replaced the spark module and the "clicking" did not go away. What should I do next?
Best Solution
posted on Oct 05, 2007
Thanks for Trying (70)
fridgetech
Rank:Guru Guru
Rating: 88%, 706 votes
There must be a problem in one of the switches which is behind one of the knobs. Will have to check each switch with a meter.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
caninekid
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
guess it's time to purchase a new oven - won't be purchasing Tappan ever again.
Solution #3
posted on Dec 28, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
most of the time the ignighters switches come in sets of four so just see if yours does and replace them all
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
Frigidaire smooth top range
I dont know what year the... Answer This...
Range noise
gas range makes loud buzzing... Answer This...
Oven and stove do not lite and...
When I turn a knob on the... Answer This...
tappan tgf351ese oven not...
i have an oven that was in the... Answer This...
All stove ignitors firing...
Igniters for all 4 stove... Answer This...
8 Other Users Have The Same Problem - Continued
Comment by P Patto, posted on Nov 25, 2007
Just bought this Jenn-Air JGS8860BDP range.. used it once.. the right rear burner has no spark..all of the other 3 burners spark when the knobs are turned but not the right rear... Any ideas ? that burner had not even been used to cook with yet...
Comment by reg318, posted on Nov 25, 2007
Same thing happened after cleaning the top of the range. Turned the breaker off for a few hours to no avail.. I see the solution about checking switch with a meter, but what if I don't have a meter? Thanks.
Comment by Guest, posted on Nov 04, 2007
Same problem. Help!
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
