Question about Toshiba Satellite A60 Notebook
TOshiba Laptop Not Charging or booting
My toshiba this morning didn't want to charge and the light of the AC connected is flashing. is it the mother board or just the charger?
Check the power connector (on the back of you laptop - through whitch you feed power to the mother board) for lose or if it's broken
Posted on Oct 03, 2007
Toshiba a350 battery not charging
The constant current regulator on the mother board has failed or there is a bad connection on the battery connector if the laptop works on the power supply.
Mar 21, 2013 | Toshiba Computers & Internet
Is there any way to get past the EC power restriction foir BIOS FLASH...My L675D-S7049 Toahiba Laptop had a DEAD (Totally) battery due to a friend...AC shows input but NO CHARGING with new battery (OEM)...
The bios will and does not affect battery charging. Battery charging is carried out before the system and is a switch mode charger on board before the processing. If it required the processor to work and a bios, it would not charge when switched off!
I would suspect the OEM battery for the flashing light but the laptop should switch on with just mains power.
Has it been overheated?
May 29, 2012 | Toshiba Satellite Black 173 L675DS7049...
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
Toshiba Laptop not charging
So confusing...Laptop AC Adapter nowadays has AUTOMATIC VOLTAGE, meaning it doesn't matter if it is 110v or 220v. Maybe you've got a FAULTY BATTERY. Remove the battery and plug in your AC Adapter to outlet and to your laptop and try to power-on.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have a Toshiba 1415 S173 laptop I'm working on for a friend. On AC power, plugged in light comes on, stays green. Battery light will glow amber/yellow while charging, and then glow green when it is...
Hi
Once before I had a similar Toshiba come into the shop. Try turning the unit on without the battery installed and on the good Toshiba charger. The computer batteries have a minimal current level and once power has gone below this level they will cause all kinds of problems. If the Toshiba now works, you're home free - just replace the battery. If it doesn't work then it will have to see a reputable repair person who can troubleshoot chip issues. I've seen these clone power supplies do all kinds of things to computers.
Mar 13, 2010 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba A135-S4527 laptop ** Battery not charging!
Check the power input jack soldered connections for cracks, resolder them as necessary.
May 15, 2009 | Toshiba Satellite 1135-S125 Notebook
"Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Feb 18, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Toshiba Satellite A60 Notebook Logo
121 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
