Question about Compaq Evo N1020V Notebook
Dead screen when i powered up my compaq evo n1020 note- book the fans start up healthly, and the CD/DVD drive worked proper, but the screan is dead, and my battery is not ok, and before that, my I\O configuration in BIOS is just done for parallel ports only, no CD\DVD, or removables.
  • bokho Oct 03, 2007
    My lovly fixya responds carefully, and quicly.
  • billybond Feb 15, 2008
    I was getting message that vga couldnt find enough resources and was told to uprade bios from hp site. I did and when it restarted i have black screen & fan runs, thats it. Please help.
    Novelist:
    Scholar:
  • 167 Answers
Restoring the BIOS settings to the default should solve your problem.
Posted on Oct 06, 2007
SOURCE:
My presario 900 wont start
Either the motherboard is "dead" or the power-supply is "dead".
It's easiest to FIRST try a different power-supply.
Jan 04, 2014 | Compaq Presario 900 /1500 Series EVO...
My compaq evo D500 sff blicks red light can't start
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jun 18, 2012 | Compaq Evo D500 PC Desktop
The DVD drive in my wife's Compaq Evo N600C has stopped reading CDs. It reads DVDs fine, but doesn't recognize any CD or CD-R.
1. Right-Click on My Computer -> Properties
2. Click on Device Manager.
3. In the list of devices, click on CD/DVD Drives.
4. Select ur CD/DVD device and right-click on it.
5. Check the Device Status (Working Properly)!
6. If required, You can update / uninstall / rollback the driver for this device by clicking on, Driver option.
7. Apply settings and close dialog box.
8. Restart the system.
if it helps tell me....tc! :)
Jan 03, 2010 | HP Compaq Evo Notebook N600c
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
Compaq presario 900 512 ram to 1 gb?
go here http://www.corsair.com/
and do a memory scan
Jul 07, 2009 | Compaq (291647-001) for Presario 900 /...
Compaq eve n610c
i think you need to take your laptop to computer shop for repairing. your system's operating system might be crash so you need to do either recovery or do a fresh installation of opearting system by putting the os cd in your cd/dvd drive.
Jul 12, 2008 | Computers & Internet
Fans won't start on my compaq evo
I suggest replacing the fans with new fans. Fans do expire and they need to be replaced.
Aug 30, 2017 | Compaq Evo D300s PC Desktop
Cpu Fans
your last lined is typed wrong, works, should be worked, (past tense) right?
I guess the screen is 100% dead and PC silent right? no text to the screen ever.
old laptops 15 long years old in fact (can be)
old pentium4 with a square 4:5 screen wow.
some fans are modulated, ever heard of PWM? (this one is)
so did you first remove relic old main battery first, it will be shorted now, and when shorted it overoloads power buses.
then the coin cell is NEXT , never seen one last 15 year, not me.
why wait get the HP RTC cmos coin cell. for 2 bucks and put it in.
dead PC 101, above done, fan dead.
1: power pack 19vdc, it must be at least 18.5vdc,
at the mobo not in hand by it self. the means under load testing.
normal load. we use a thing (20bucks) a voltmeter DMM to test all power packs. or replace it for $10 if you can even find one this old.
there is more lots more, if one component on the mobo shorts.
we can find that but , ill stop here, if you can get this far.
now the book on your PC, page 91 shows how to change the CMOS battery, here is the steps (compaqs are PITA)
this page. (Compaq then thought it lasted 20 years, hahahahaha)
https://www.manualslib.com/manual/273370/Hp-Evo-N1010v.html?page=91#manual
Keyboard cover(page 2-13)
Speaker (page 2-15)
Keyboard (page 2-16)
Switchboard PCA(page 2-19)
CD/DVD (page 2-20
Display (page 2-23)
Top case (page 2-26)
Floppy (page 2-32)
Heat sink (page 2-40)
Motherboard (page 2-50) bingo the coin cell.
the fan is modulated. (it is controlled at all times for speed)
at power on most laps it run real fast first. then slows.
this is by DESIGN to keep noise lower.
id the CD does not eject try on damand there is no power.
if fan is dead, to, power is gone
one guy asked what power means. ok
it means all 3 4 or 5 power regulators on board work
5v
12v
3.3.
1.8 and more, if any power reg shuts down the PC is DEAD.
Jan 18, 2018 | HP ze5560US (DP473U#ABA) PC Notebook
Compaq presario 1200-118xl note book problem
Anyone find the answer to this problem yet? I'm having the same problem too..
Feb 06, 2008 | Compaq Presario 1200T and 12XL Series...
Computers & Internet Logo
117 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
