Miele w1203 fault
After power on buzzer is on and drain pump runs no lights on panel except buzzer and when buzzer switch pressed buzzer silenced but no lights and pump still runs. have checked inlet filters and sump switch seems to work properly.
  • 1 more comment
  • Anonymous Dec 04, 2007
    same problem here with W1203. no other lights except buzzer are on. I had drained all water and removed any debris. dont know what to do
  • paulio Dec 14, 2007
    Make sure interior door light lens is locked
  • Anonymous Jul 07, 2008
    Same problem here. Was told that I should wet vac the water out since the drain pump float might be up in an overflow area. But did not help. How do I make sure the door light lens is locked.
Use the small orange tab to tighten down on the light just inside on the top of the door. i had the same symptoms and it fixed them right away.
Posted on Feb 22, 2008
Miele w1203 washing machine at end of cycle fault lights intake & Drain and the ---on panel lighted Buzzing & will not operate now. I have cleaned drain at bottom left
There are two impellers, one of which may be stuck. It's easy to wiggle them with some tool to free them up. Search on YouTube for videos on where to find them (both are right in the bottom under the filter screen so easy to get to).
Jul 11, 2017 | Miele Dishwashers
Miele 1203 washer failed during a cycle and buzzer on no fault lights
check all the wirings connectuions! and maybe you have dirty rottary switch! you can clean the switch!
Oct 01, 2007 | Washing Machines
Miele W1203 washer, buzzer sound with no indicator flash. how can i fix it
It sounds as if there is a leak and water in the pan (bottom of the machine) the front of the machine would have to be removed to check and determine the cause of the leak
Aug 02, 2014 | Miele Washing Machines
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Jan 17, 2013 | Miele Washing Machines
Miele Advanta dishwasher beeping
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
If it does not come on, start over.
^ Press the program button briefly four
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
Miele W1203 washer drain and intake lights flashed together and now will not change modes. Can I reset it so that it will work again?
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work. If Fault reoccurs then you have a leak.
May 17, 2010 | Miele W1203
Front lower left corner has an access door.  Pry the access door open.  Inside you will find a yellow tab that will open the machine glass bubble door. Below the yellow tab is a cca. 2.5 inch screw-in plug.  Place a pan in front of the machine and unscrew to plug.  Water will drain out of the machine.  With the plug removed, tilt the machine forward past 45 degrees until all water has drained out.  This will reset the washer.  Insert the screw-in plug.
Apr 14, 2008 | Miele 11120301 W1203 Touchtronic Washer...
Washing Machines Logo
212 people viewed this question
Top Washing Machines Experts
