Question about Soltek SL-915G Pro-FGR Motherboard
No signal in monitor
I switch the pc on but there is no signal in monitor,neither with the onboard card nor with the pci card. the monitor has no problem for sure. im waiting for your help. thank u
  • 23 Answers
Check the powersupply unit. if the unit does not take load there is no display. the psu will on but does not have the capacity to boost the power to the mother board. please check changing it
Posted on Oct 06, 2007
SOURCE:
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
Ive installed the ati his radeon ice q graphics card and my computer will not boot,Why?
hook monitor cable back to your onboard video port then 1st make sure you have already downloaded the driver for your new graphics card. then at start up go into system setup and go to your display and make sure that you have your new graphics card enabled as your primary graphics instead of onboard video. it will say something like 1.Onboard 2. AGP/OR PCI MAKE SURE YOU DONT HAVE YOUR ONBOARD ENABLED AS YOUR PRIMARY VIDEO. AFTER THAT JUST SAVE AND EXIT THE JUST HOLD POWER BUTTON DOWN TILL PC SHUTS DOWN THEN SWITCH YOUR CABLE MONITOR CABLE FROM THE ONBOARD TO THE AGP/PCI CARD THEN RESTART YOUR PC. THEN YOUR PC WILL SAY FOUND NEW DATA AND WILL INSTALL THE DRIVER YOU HAVE DOWNLOADED FOR IT THEN YOU SHOULD BE OK IF THE CARD IS COMPATIBLE WITH THE MOTHERBOARD
Jun 07, 2011 | MSI KT4V (MS-6712) Motherboard
Ibm xseries 235 eserver....all of a sudden stopped booting...it was set up through a kvm swtich, the kvm detects a signal and lights up the apprpriate port, yet nothing is displayed on the monitor....
Please expalin how you know "drives are good" (sic) As it would appear to me that this is indeed your problem? Unless as you say the video card has turned up it's toes. As you said the best way to check that is to enable the onboard Video and check, exactly what happens when you do that? Yes it will automatically use the video, it would install a generic video driver,and show video, are you sure the monitor is OK,have you swapped it out? Simply removing the Video card will automatically enable the onboard video, so you won't need to get inro BIOS. Check the RAM too, and remove any other cards in it.
Feb 23, 2010 | IBM eserver xSeries 235 8671
A pop up window appears and says no signal analog
this is most likely a pc hardware issue and not a problem with the monitor itself.
1. check cables and power switches.
2. remove devices from power strip and then plug them back in one by one.
3. try alternating memory sticks to diagnose if one may be bad.
4. remove pci dial up modem card.
5. if you have an agb, pci, or pci-e video card remove it and plug monitor onto the onboard video if the option is present. if not test with a known good video card.
6. if possible test pc power supply with known good power supply as it may have gone bad.
any damaged piece of hardware could potentially cause a system to not post or display to a monitor check these first as they may be the most likely culprits.
hope this is helpful.
Dec 10, 2009 | ViewSonic VA721 17" LCD Monitor
When I plug my monitor into my video card i get "no input signal" yet if i plug it into the onboard slot it works.could my PCI-E slot be bad?
Did you add a video card? If you have an AGP slot, it is best to put the video card in it. If so you need to go into the Device manager. Remove, disable or uninstall the onboard VGA driver. Go ahead and remove the PCI video card driver as well. Power down PC. Make sure monitor is hooked up to the Video Card, not onboard VGA. Power on PC. When Windows loads, it should detect the VGA card first, but if it detects the onboard first, ignore and don't setup onboard first. When Windows detects the card, load the necessary drivers when prompted. There is no need to reinstall the onboard driver for the video unless you wish to hook up two monitors.
Nov 08, 2009 | HP w1907 LCD Monitor
When i turn the computer on the monitor says it is in power saver mode and to activate using the pc please help
Sounds like your monitor is not getting any signal. The monitor is probably working fine its the video card or connection that is having the problem. Check all cables, then check to make sure video card is working. Does your computer POST without any problems when you turn it on? Do you have an onboard video port and a AGP/PCI-e/PCI video port? If so, is your video connected to the onboard or the AGP/PCI-e/PCI
Jul 08, 2009 | Dell E773C 17" CRT Monitor
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
No Video Signal
reboot in safe mode, safe mode will put the pc in vga mode and use whatever video it can find.
If no good U may have a problem with the MB.
May 23, 2008 | Gateway GT5228 PC Desktop
Problem with display
Some iiyama's have 2 inputs. One DVI and one analog. Also, some of the older ones used BNC connectors. What I'm getting at is make sure you have the right input selected in the monitor's menu. Hope this helps....JF
Apr 02, 2007 | iiyama S 900MT1 (White) 19" CRT Monitor
Soltek SL-915G Pro-FGR Motherboard Logo
Top Soltek Computers & Internet Experts
Ekse
Paul Bade
Steven Wander
Steven Wander
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
