SOURCE: car alarm preventing car from starting
Try removing the alarm system relay, some car alarm has also a fuse on the alarm that you can remove.
Many car alarms unlock by inserting and turning car key while you connect the battery.
SOURCE: Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
I am having trouble also but I need to know how to disconnect the alarm. I would appreciate it if you could help me out seeing that you have disconnected yours. Thank you
SOURCE: How do I reset factory alarm on a 2000 Subaru
you HAVE to get a remote and unlock the car.the dealer may be able to turn it off with the obd2 system,you have to call subaru.
