Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Does not get power from any wall outlet
No power...tried various outlets and still nothing...is this something i can fix myself ot do I need a tech.?
    Problem Solver:
  • 14 Answers
First thing you may want to do is pull the back cover and see if the fust is blown next to the power cord. Make SURE the power cord is pulled before you try this. You could have had a power surge that caused it to go out, but usually this points to a larger problem. It's a good first pass thick to check though.
Posted on Dec 23, 2007
6ya staff
SOURCE:
Wall plug for TV buzzes
Have the outlet checked by a qualified electrician. Sounds like either a power issue or ground. You should not get a buzz from an outlet for any reason.
If you plug something else into the outlet does it make the same noise?
If yes, something going on with the power. If not, then the TV power supply might be doing it, but the noise would be behind the TV and not the outlet.
Aug 17, 2014 | Sony Bravia 32-55 Inch...
Moniter output not connect
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 20, 2014 | Computers & Internet
My Dell XPS 410 computer will not start, won't do anything.There is however an LED light on the Motherboard labled Stdby Led, this is lighted but the compter won't do anything? I am needing someones...
Your computer power button may not be working, or the CPU may be bad and it can also be the motherboard is faulty.You need a new case or fix the power button or try another CPU in the computer or replace the motherboard.
Aug 16, 2010 | Dell XPS 410 PC Desktop
42 Inch Samsung Flatscreen; 1.5 years old. Won't
First test the wall outlet, try plugging a lamp into the same outlet see if it works. If the outlet works then read the following below. If the wall outlet doesn't work then plug the TV into another outlet.
If its not the wall outlet:
Unfortunately the power supply has a problem sustaining DC output. This can be caused from several fault scenarios. Get someone who is technically savvy and I will show them via e-mail what to test to fix this problem for you. Or you can take it to your local repair center.
Dec 20, 2009 | Samsung HP-T4254 42 in. Plasma Television
Tv won't turn on
Try plugging something else (a lamp?) into the power-outlet, to see if the wall-outlet is providing power.
Try plugging the TV into some other "known-good" wall-outlet.
Take the TV to a repair shop, and have them trouble-shoot.
Nov 09, 2009 | Soyo Televison & Video
No Power
Usually there is no fuse in the printer itself. The big block that you plug into the wall is actually a transformer. It converts the 120V power from the wall outlet to a much lower voltage and also converts it to DC power.take the plug in end with the cube transformer in it and bring under a good light and it will read the specifications about that power converter. What sometimes happens is that the transformer inside that cube fails (through various causes) and thus produces no voltage or the wrong voltage. Take the plug with you to an electronics store of your choice and they will direct you to a universal 120AC to a DC transformer (it will have various settings and various plug adapters) and then follow the instructions to match the voltage on the old power converter. I hope this helps you out.
Jun 04, 2009 | HP Photosmart 3210 Printer
Sony kv-32sf12 -will not power "ON
Try the 60 seconds unplugging of wall plug in your outlet. Or check your line if this have surge protector. Temporary plug your unit to wall outlet directly. Just check if it still within voltage operating range.
May 10, 2009 | Sony KV-32FS12 32" TV
MFC-5440CN will not power on
connect the machine directly to the wall outlet. if it is within warranty,call TECH support.if not,bring the machine to an authorized service center.the machine maybe malfunctioning
Oct 30, 2008 | Brother MFC-5440CN All-In-One InkJet...
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
