Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Food is defrosting in my hotpoint frost free fridge/freezer
I bought my hotpoint frostfree fridge/freezer 6months ago. I just transported the fridge due to my moving into a new home. Left the fridge to settle after 6hours and then switch back on. But now the freezer is defrosting all my food. The super cool, fast freeze and the power on button are beeping continously. Pls help me find a solution to this problem. Thanks
  • Anonymous Mar 15, 2014
    Fridge is freezing contents
    New Friend:
My freezer model ffa47x is makeing a noise like a drill think its needs defrosting but cannot find it in the manual how to
Posted on Jan 03, 2010
  • 290 Answers
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
  • Michael  Lindley
    Michael Lindley Oct 08, 2007
    Just wanted to follow up on your refrigerator problem and see what you found wrong.
    Thanks/Mike
SOURCE:
Can I transport one of your 2 door Fridge/ freezers laying on its side.
only transport a fridge or freezer on it's side if the upright transport is NOT an option.
any chiller using compressed liquid/gas and placed on it's side should be left for 24 hours to settle before powering at the mains, this will allow the coolant time to sink where it should be and prevent the pump (& chiller) from failing.
Nov 23, 2017 | Refrigerators
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Just had delivered a logic fridge freezer 6months old is it safe to use straight away
If the fridge was transported standing up, it is safe to use right away. If it was transported on its side, I would wait 24 hours.
Oct 02, 2014 | Refrigerators
Hotpoint ffa52 fridge freezer
that is likely where the link for water an elect is remove cap an check the connections. in transport its reconnected when the door is off. an sometimes they get loose
Jul 25, 2014 | Hotpoint Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Refrigerator was bought 5yrs ago(brand new)it worked perfectly until then....put it in storage 4 six months...when i moved it into my house i plugged it up...can hear it on but yet to get cold....left it...
Hi
Is your fridge compressor motor working and can you hear it turn on and off every hour or so. Not to be confused with the sound coming from the fan inside the fridge.
If the motor is working but neither the fridge or freezer compartment are getting cold, then there may have been a rupture during transport and gas has escaped.
Ash
Sep 02, 2011 | Hotpoint Refrigerators
I woke up one morning and the fridge is not working but the freezer is working great. The fridge does not want to get any cooler than it used to be, it is not keeping our products cold. My fridge freezer...
the damper vent door between the freezer and fridge has stuck shut due to being frozen,you need to remove the freezer wall on the inside rear area to see if this door is shut and try to get it to move,also make sure the evaporator fan is running too so air gets moved from the freezer to the frideg
May 19, 2011 | Hotpoint RFA51 Bottom Freezer Refrigerator
Just need to know how long a fridge needs to be vertical after being transported laying down...
i recently bought a fridge for my girlfriends and the manual said 24 hours this is to let the liquid components of the fridge settle hope this helps
May 04, 2011 | Maytag MTB1504ARS Top Freezer Refrigerator
Bought a 2nd hand fridge freezer,worked fine before we moved it!The dippy other half transported it laying flat.Now it doesnt work!We left it 48hrs after transportation for gases to settle.There is...
Sorry but dippy other half probably ruined it....:-(
Try plugging it in for a bit and then plugging over a period of a couple of days... it may go after awhile...
heatman101
Sep 18, 2010 | Refrigerators
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
1,045 people viewed this question
Top Hotpoint Refrigerators Experts
jasbo
jasbo
Steve Allison
Steve Allison
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
