Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Stops working after 2 minutes and "Rinse and Hold" keeps flashing
Someone else reported this problem and the solution was apparently to disconnect the water-supply pipe and remove the plastic filters giving them a thorough cleaning. This should then allow the water to flow through easily. I have just moved into my new flat and the dishwasher is in-built. I know this is a stupid question but how do I get to the water supply pipe? I don't want to have to pay for an expensive plumber so any help someone can give would be greatly appreciated!
  • dont do diy Dec 03, 2007
    We have just integrated our new zanussi dishwasher and it appears that no water is getting in. Where is the water supply and what should I do?
  • 209 Answers
When you open the door, there is access to screws around the inside edge and under the front lid, where the rubber lip is and down the side, remove these and the appliance should pull out gently
Posted on Oct 03, 2007
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Flashing lights on my dishwasher
Have you disconnected it from the socket to try a reset? If not firstly try this, if flashing continues, please hold down the on/off button continuously for about 5-10 seconds during that time it will beep or flash but keep hold until this master resets the dishwasher, then try a normal cycle, this should then resolve this, unless the PCB board has gone wrong, in which case I would contact the maker of it is still under warrentee, if no warrentee then call a local repair person, most offer a free quote if you ask for one... I hope this helps....
Feb 21, 2018 | Dishwashers
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
My Zanussi dishwasher wont run a programme
Hello Paul, The first thing to try is to clean the filters at the rear pipe(s) that connect to the main water supply. It is quite common that when the water-flow is impeded, the programs may stop with flashing lights depending on the rate/amount of blockage.
So, pull out the unit and disconnect the rear pipe and give the in-line filters(s) a good going-over. Please let me know if this does the trick...
Best Regards,
Peter...
Aug 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Lights flashing but machine not working
hi there i would check the connections to the heater and ntc both can be found behind the lower inspection cover at the rear, UNPLUG FROM MAINS FIRST AS LIVE PARTS EXPOSSED BEHIND!!!
Feb 08, 2008 | Hotpoint Aquarius WD640 Front Load...
Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Dishwashers
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Mitsubishi WS73713 - Now working - Timer light flashing.
hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
Dec 30, 2007 | Televison & Video
Zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
Jan 02, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
372 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
