Question about LG GSA-4160B DVD±RW Burner
For some reason my burner won't recognise these discs. They are both TDK and when I tried updating the firmware the programme couldn't locate my drive and there was no browse option to find it. I followed the "read me" file attached to the firmware upgrade to the letter. It was a301 upgrade. The message through nero disc info is something along the lines of "No Disc Found". I can still burn dvd+/-R 4.7gb discs and the drive shows up in My Computer & in device manager. Anyone got any suggestions???
  • 51 Answers
Re: DVD+RW & +R DL
In order to upgrade the firmware the LG drive MUST be on it's own IDE channel and 60 conductor cable and be set as master.
Quoted from the LG support firmware file download:
Critical Instructions: (to be followed carefully)
1. Connect the drive as master by it self, on the secondary IDE controller with no other device on the same IDE cable, making note to set the jumper on the back of the drive to the master position.
To check this open the computer case.
If you need more assistance, post here again.
Posted on Oct 19, 2007
0 characters
3 Points
Won't recongise DVD+R dual layer 8.5Gb TDK DVDs.
Most of the drives are not capable of recognising specific color medias (specifically purple), try using perl, silver media for dual layer disc
Jul 17, 2010 | ASUS DRW-2014L1 DVD±R Dual Layer Burner
Cd/dvd burner will only recognise blank cd discs not blank dvd discs
Find some "older" blank DVD-R, or DVD+R, or DVD-RW disks, and insert them.
If they are recognized, then access LG's web-site,
and look for a downloadable "firmware update" for your model.
The newer firmware adds support for "newer" DVD media.
If all else fails, replace the CD/DVD device.
Nov 06, 2009 | LG GMA-4020B Super-Multi...
Tdk dvd rw aid+420n
this is the 420N, not the 440N?
is this an internal or external burner?
what operating system are you using?  on Windows XP, there's a good chance that you can just use the default drivers for that...
the best set of drivers i can find is here:
but most of those are firmware updates, or for slightly different models.
Mar 28, 2008 | TDK Indi DVD 420N (AID+420N) DVD+RW Burner
CD Burner doesnt see a Disc is in already
failure my friend. try to restart your computer, this way, after restarting, your drive will recognize that a cd is in.
if it still doesnt recognize that a cd is in, try updating the firmware of your drive and clean the lenms of your cdrom too.
Mar 22, 2008 | TDK ( ue401248bx) CD-RW Burner
I have the same issue with the LG GSA-H20L and the LG GSA-42N, but mine was with TDK DVDs.
I contacted LG Support and they told me that TDK disks are not recommended for use with their DVD Burners.
I asked them if there were any others they did not reccomend and they said no.
Going through my cupboard, I found Memorex Printable DVD-Rs that will burn OK.
I also tried Sony DVD+R and a generic brand, but they will not burn either.
I also found that these LG drives do not recognise Laser CD-R.
In short, for burning, try either Memorex, LG and some others, but don't try TDK, Sony or Laser.
Good Luck
Jan 13, 2008 | LG GSA-H42N 18xDVD+-R, 12xDVD-RAM,...
YEP the firmware does not support that type of media
you can try upgrading the firmware but that may not help
eighter use a different media of change the drive
Dec 21, 2007 | Pioneer DVR-109 DVD±RW Dual Layer...
Unable to burn DL discs
Whats ur DVD specs, it has to be DVD-DL capable, not just and DVD can burn both DL
Dec 09, 2007 | Sony DW-G120A DVD RW Dual Layer Burner
My SONY DRU-810A DVD Writer doesn't work with TDK DVD+RW Disc
some dvd brands dont work with all dvd writers, so your option is to try another make, if that works ok then it's not a writer fault it is just that the media make is not compatable. if you start to see problems with all makes of disc then the writer laser is faulty and a replacement drive neccasary.
May 11, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
LG GSA-4160B DVD±RW Burner Logo
171 people viewed this question
Top LG CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Terry Allen
Terry Allen
Are you a LG CD and DVD Burner Expert? Answer questions, earn points and help others
