Question about Xerox Phaser 8500/DN Printer
Error code 11,009,46:1444 on Xerox Phaser 8500
Does anyone know what this error means? I'm unable to clear it from the screen and the printer is non-operational. I have searched on Xerox support pages but this error code does not see to be recognised.
  • 212 Answers
The 11,009,46 error in my experience means that, at some point, the printer lost power during an electronic action. in some cases an NVRAM reset will do the trick, but if it doesn't, one of the electric boards has been blown up. XEROX are very protective about which board to replace, so you're quite stuck with their own service in order to have it repaired.
Posted on Mar 15, 2011
Printer Error 11,009.46 Message Reset the Printer to the Factory Defaults (NVRAM Reset)
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAM to their factory default values. The print count and the Adobe firmware serial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
TIP: take the last part (:1444) off when searching. Try at your own risk
Posted on Nov 09, 2007
  • 3 Answers
A fault code search on Xerox's website says this is an electronics module interface fault--just doesn't say how to fix it!!
Posted on Oct 04, 2007
SOURCE:
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Xerox phaser 8500 error code 09, 038, 46:4597
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
Aug 11, 2013 | Xerox Phaser 8500/DN Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 09.005.40:64314
Best way to do that is take a screw. I use a drywall screw, and twist them into the blocks and slide them back and out. Remove all of them, see if there is just one stuck or not compltely advanced in the loader. Then replace them all . That should clear the code.
Feb 03, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8860 error code 08,030.46;21225
The Media Path Motor Stalled
Solutions ranked by relevance:
Make Sure There is no Paper Trapped in the Paper Path
Power the Printer OFF, Wait 30 Seconds and Then Power ON
Oct 01, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8500
That is a print head movement fault.
There are 2 things that normally cause that. One is the print head pivot block becomes contaminated with ink, the other is the wiper blade tacks to the print head.
If you want instructions let me know.
Jan 22, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500N Printer Error
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 reports Internal Error
I would suspect the elecrtonich module has gone bad.
Without an error tht is my best guess.
Oct 23, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
1,149 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
