,cool air is blowing and drum is turning. Dryer approximately 3-4 years old. Does Cycling thermostat need changing, also?
First i would cheak your breaker panel to see if your double 30 house breaker kicked out on 1 side or if you have a voltage meter cheak for power you should have 220 volts.going across on you plug box.If those are good chek your thermal cut off located on your heater housing on the top and cheak for continuity across.If good you need a element.cheak that across on tester to find out good luck:) PS If that is good you may need timer or motor
DID YOU CHECK THE HEATING ELEMENT WITH YOUR METER?CHECK THE CYCLING THERMOSTAT ALSO-MIKE
