Question about Logitech Cordless Internet Handset Phone
Logitech internet handset "UNAVAILABLE" error
Installed driver and plugged in USB base station, and it WORKED like a dream this morning, however now I try and the (fully charged) handset only gives me "UNAVAILABLE" when I try to show my list of Skype contacts. Also, whoever I call, I get a "busy" tone but the call isnt even going out because theres no delay between calling and getting the signal. Have tried using + / 00 / 011 prefixes as suggested but doesnt change anything. Have also rebooted and restarted Skype a few times. HELP!
  • 5 more comments
  • cosima Dec 19, 2007
    It worked perfectly at the beginning. Then suddenly .....
    The error message I get on the Logitech Internet Handset is "Access to Skype is rejected.
    Did anyone encounter the same problem and does anyone know how to crrect it?
    Thanks
    [email protected]
  • Anonymous Dec 31, 2007
    same problem...i get a busy signal when placing skype out calls with this logitech internet handset? any help?
  • sandeepsandy Mar 05, 2008
    yes i m not able to install the software of Logitech Cordless Internet Handset Phone and drivers as well so please tell me that how can i download them
  • ecp26 Nov 11, 2008
    I also have the problem that the contacts are unavailable. It had worked just fine for months and the other day the call got cut off and now the Handset cannot get the contacts. It says UNAVAILABLE!!
  • GJROPP Jan 04, 2009
    I get sam message.."access to skype unavailable! 'UNAVAILABLE'
  • Anonymous Mar 20, 2009
    search base
  • nietje Mar 27, 2009
    sinds ik de nieuwe versie van skype heb geinstallerd kan ik mijn logitech cordless handset niet meer gebruiken.Hij meld dat het niet mogelijk is en ik krijg de mededeling "losgekoppeld", dat terwijl alles toch goed aangesloten is.
  • 3 Answers
Mine was working fine at one point. I had been using it the night before without issue. However later on when I went to make a call the next day the handset said Disconnected.
Any Skype functions said "Unavailable". Rebooting the PC, Restarting the Headset Software and Skype didn't fix the issue.
The fix for mine was to go into "Menu" then "System" on the Handset and do a reset. Soon as it was done, the Skype info popped backup on the handset and it was fixed.
For those who haven't changed it, the default PIN on these handsets is 0000 <-- Zero's
Posted on Apr 08, 2008
The solution above works, but wasn't made clear to me how to reset the handset, and it isn't in the manual.
I was stymied because: "register" was not a menu option for me on my handset?
It turns out there are TWO menus. Two access the second one you need to disconect the base from the computer.
So to reset the handset:
1. Discontect handset base from computer
2. click on left top button to access Menu
3. Click register.
3. Enter pin (defualt is 0000) - four zeros.
You're back in action.
Posted on Oct 27, 2008
    New Friend:
Uninstall windows live messeger and reboot :)
Posted on Nov 17, 2009
None of the solutions provided worked for me. In the end, I had to unregister the handset from the base unit and re-register it.
Posted on Sep 27, 2008
Under the latest Skype -version 3.20158 - selext Tools, the Options, then Advanced. Look at the bottom of the menu and you will see "Manage other programs access to Skype". Select that and you will see "LOGI_HD5.EXE not allowed to use Skype" or something to that effect. Select change and allow it to use Skype. Problem solved.
Posted on Mar 02, 2008
I was having the busy signal when calling out.. here is what worked for me.
When dialing a number hold down 0 to get the + before you enter a number.
For example making a call within the US to a US number it would be: +6045556666
Posted on Jan 23, 2009
SOURCE:
I have a ge27851f-2 cordless dual phone and both handsets say unavailable even when paired at the base.
If the base station is plugged into the phone line you should be able to designate one phone as the master. That phone should be on the base station when charging. If you look in the manual it should show you how to redo the master. It's usually just pushing a button when on the station. Just takes a second. That will also enable the phone to work with the base station. It locks out any phones that haven't been physically connected to the bases. To do the second phone you may have to do a slightly differant process to register it with the bases.
Nov 04, 2009 | GE 27851FE2 Phone
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
Always "Disconnected"
this dosnt work this way,
go to the logitech site, look fore the right set, disconnect the usb connector from de pc, then download/install the right software en untill you asked fore plug in the usb connector then plug in, it will working, unless you have installed msn under windows vista, this is not working togehter.
Aug 20, 2009 | Logitech Cordless Internet Handset Phone
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
MY NETGEAR SPH 200D IP PHONE NOT CNNECTIONG TO INTERNET . I GET MESSAGE SYSTEM STARTING UP BUT NEVER WORKS. I DONOT HAVE INSTALLATION CD
Follow the steps below to resolve the issue:
1. Disconnect the power to the base station.
2. Remove the batteries from the handset - leave them out for a few minutes and when you replace them, don't try to turn the handset on: just put it in the charger base and leave it for 15 minutes or so.
3. Plug in the power to the base station and leave it for a minute to settle down.
4. Take the handset out of the cradle and turn it on.
Rate it, if it helps.
Apr 13, 2009 | NetGear SPH200D IP Wireless Phone
Logitech cordless internet handset for skype -- base unit problem
You can uninstall the Skype Application and reinstall it in compatiblity mode and chose XP. To do this right click on the install exe and go to the compatibility tab/section and from the drop down chose XP. Then try reinstalling it.
That has solved a lot of issue for me with Vista.
Let me know if you need anymore help or if that does not solve your issue.
Thanks,
CompGoddess
Dec 29, 2008 | Logitech Cordless Internet Handset Phone
Quickcam unavailable
have you tried directing Vista to search you Logitech installation disk?
Don't install the main software, just plug in your camera and then, when
vista asks for drivers, get it to search the logitech CD. This is what i did
witrh my logitech camera and it installed without any problem.
http://xphelpandsupport.mvps.org
http://vistasupport.mvps.org
or you can fix your usb driver and try it in anothrt port of usb
thank's
cropp
Mar 07, 2008 | Logitech QuickCam Chat Personal Web Camera
Ge cordless phone station 2 shows unavailable
You have to register the hand set in the main base. Place each handset in the base for 15 seconds minimum. It will change form unavailable to Ready when it grabs the signal from the base. If the power goes out, you will have to re-register each hand set in the base before you use them again.
Jan 14, 2008 | GE 25932 Twin Cordless Phone
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
May 27, 2007 | GE 26938GE1 Cordless Phone
Logitech Cordless Internet Handset Phone Logo
2,056 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
