Question about 3M MicroTouch 17" CRT Monitor
Monitor not working
Hi i am facing problem with my 3M micro touch monitor. when i switch on my monitor after 10mint i will start shaking.what could be the reason.please help. thanks
  • 57 Answers
~Could also be a problem with the degauss circuit, either way, it needs a techie to fix it.
Posted on Dec 21, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
If it is completely shaking then problem is in power supply filter ckt. 1 please check main filter capacitor. 2 check bridge rectifier diode for open. 3 loose connector in power supply. But if it is shaking on top then check for horizontal oscillator section. if you are not rech. person take the help of skilled tech. good luck.
Posted on Oct 08, 2007
SOURCE:
I purchased a 3M 15"
This display uses a capacitive touchscreen. It relies on the conductivity of your finder work. It may be that it has lost sensitivity and only works when there is a path to ground through your body. If this is the case then the touchscreen will need replacing.
Feb 18, 2011 | 3M 11-4922-129-00 (Black) 15 in. Flat...
Dell touch screen uses Touchware to calibrate. The Touchware calibrate button is grayed out? Not sure why?
get the latest touchware driver from 3M from this link http://solutions.3m.com/wps/portal/3M/en_US/TouchSystems/TouchScreen/CustomerSupport/TouchScreenDrivers/
Jun 08, 2010 | Dell E153FPT 15" Flat Panel LCD Monitor
Diagrama 3m touch sys 7312100 my touch not works
if you already install the correct driver, you might need to replace the touchscreen
Feb 06, 2010 | 3M MicroTouch M150 (Black) LCD Monitor
Syncmaster 720n
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
Sep 01, 2009 | Samsung SyncMaster 720N Monitor
Screen won't turn on
only the touch not works but the monitor is good
Mar 16, 2009 | 3M MicroTouch M150 (Black) LCD Monitor
Microtouch CRT Monitor has no picture
We have 3 Brand New 15" Micro Touch CRT monitors for sale 954-336-7587.
TECH SPECS FOUND ON THE FOLLOWING PDF: http://pdf.superwarehouse.com/specs/DS3MPOS108626.pdf
List for over $350 each.
Sell for 1/2 price = $175 or $500 for all 3 Monitors
Please call Glenn to: 954-336-7587
Jan 23, 2009 | 3M MicroTouch 17" CRT Monitor
Touch Screen Montior
Do have the 3M driver? If not you can go to their web sight and down load it. You'll need to know what touch card you have, Microtouch or Dynapro. The monitor will be marked hopefully or you could call tech support. Just google 3m touch screen drivers.
Aug 13, 2008 | Sampo PD-70 15" Flat Panel LCD Monitor
3M MicroTouch 17" CRT Monitor Logo
219 people viewed this question
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
