Question about Philips GoGear SA261 MP3 Player
Using Device Manager!!!
I cannot seem to get the device manager working. It opens on the computer and loads a huge library and I can create a playlist. From here I cannot transfer to the device. In the top right hand corner of the device manager window it shows HDD but with a red cross though it??? Can anyone help pleeeeeeeease!??
  • tink817 Jul 31, 2008
    I have the same problem, but how do I reset it to factory settings?
Bv,
Posted on Jun 04, 2008
  • 790 Answers
Reformat your unit! to software!
Posted on Oct 03, 2007
Ematic connect to computer
are you using windows 7 or mac? If windows, you may not have loaded the proper driver for the device and the device manager sees it, but isn't loading it. If you can get the device manager, you can look for the yellow exclamation point and then tell the system to reload the driver for it. Check your cable and your cable connection. It is possible that the connector isn't seated properly.
Dec 30, 2013 | Ematic EGS004 Genesis Prime 7" Touchscreen...
Code 43 on windows 7 ultimate
You can find more details regarding that on: http://technet.microsoft.com/en-us/library/cc725873%28v=ws.10%29.aspx
To resolve this problem, do the following.
  1. To open Device Manager, click Start, click Search programs and files, and then type Device Manager. A list of available matching items appears above the search box; click Device Manager. Device Manager opens with your computer name at the top and a list of devices that are installed on your computer beneath your computer name.
  2. Locate the malfunctioning device in the list of devices, right-click the device, and then click Uninstall. When a warning message appears that you are uninstalling a device from your system, click OK. Device manager uninstalls the device.
  3. Right-click your computer name in Device Manager and click Scan for hardware changes. Device manager scans your system and automatically reinstalls your device.
  4. Right-click the device and click Properties. On the General tab of the device Properties dialog box, in Device status, you should see the message This device is working properly.
Aug 21, 2013 | Microsoft Windows 7 Ultimate for PC
Canoscan LiDE 100 on WinXP loaded drivers+software from disk
Have you tried going to the Devices Website for any CURRENT SOFTWARE UPDATES/DOWNLOADS?
Jul 05, 2010 | Dell Inspiron 1525 Laptop
Have netcore310g adapter got cd. computer crashed had to reload everything now my wire won,t work, IT LOOKS LIKE DRIVERS WON,T LOAD -HELP. TRIED TO LOAD MANUALLY NO LUCK PLEASE ADVISE WHAT TO DO TRYING...
You will want to check in your device manager to see if the network card is not being recognized and you will be able to update the driver there.
For windows XP, rght click on my computer, select properties and then select "ahrdware" and device manager.
For windows VIsta and 7, go to your control panel and open Device manager there.
Once open, you should see a network adapter with a yellow question mark or yellow exclamation mark beside it.
In either case, make sure the driver disk is in your disk drive, right click on the network adapter and select "update driver"; then just select the "recommended" options and follow through.
If this still doesn't work, try uninstalling the device from the device manager and then install the drivers using the disk.
Thanks,
Pat
Mar 29, 2010 | Computers & Internet
7280 507 error
Cause 1 If this error occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
You need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer. Before you use Application Loader to install software on your BlackBerry wireless device, verify that the necessary device software is installed on your personal computer.
    To verify what device software is installed on your computer
    1. In Desktop Manager, click Help>About Desktop Manager.
    2. Click the Device Software tab.
    The Device Software tab lists the device system software installed on your computer. If the tab is blank, then no device software exists.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
OR
Cause 2 It may occur when all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software. Cause 3 It may occurs when the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
It may occurs when the BlackBerry smartphone is connected to a laptop computer using a docking station. You need to complete the following steps:
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
Nov 08, 2009 | RIM BlackBerry 7290
My cd rom drive won't work! Every time I go to device manager, it says ' This device is not working properly, it has failed to load drivers. Windows can not start device ' Please, any one , what can I do...
Check Device Cable is connected propertly. OS files curruption will create this problem. Check out is your device not physicaly damdaged.
Thanks.
Sep 23, 2009 | Computers & Internet
Music in file manager instead of music library
once you load the music to the phone, restart the phone than go to library and see if it says searching device or similar and it should load all of the songs in your phones memory.
May 13, 2009 | Nokia 5800 XpressMusic Smartphone
507 error resolution
The error message indicates that no applications are loaded on the BlackBerry smartphone.
The following are possible resolutions for this issue.
Cause 1
While using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
Complete the following steps:
Cause 2
All data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
Even after performing these steps if you could find the same error, please let us know so that we can provide the further resolution.
Mar 07, 2009 | RIM BlackBerry 7290 Smartphone
Dvd rw
Please go through the below provide steps.
Fixing Code 39 Error
If your CD-ROM drive is not visible in My Computer, you may see the following error message displayed with the CD or DVD drive item in your Device Manager. (Steps to open Device Manager are discussed later in the article.)
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
  1. Exit and close all applications currently running on your PC.
  2. On Start > Run type Regedit and press the Enter key.
  3. Next, navigate to the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Delete any of the following registry entries if they exist under this key:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
  7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Thank you........
Sep 18, 2008 | Computers & Internet
DVD Mutirecorder drive driver
hi, I have scoured the internet and this worked for me
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
It sounds complicated but it was actually quite simple, just make sure you delete the right files.
Aug 02, 2008 | Toshiba Satellite A100-S8111TD Notebook
Philips GoGear SA261 MP3 Player Logo
74 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
