Question about Printers & Copiers
Brother DCP 115C
When i plug in my printer ( Brother DCP 115C) in my pc i get this error : Registry editor , Cannot export P4_USB_chip.req. : Error writing to the file . There maybe a disk or file system error. Can you help me ? thanks in advance , Mats
5 Suggested Answers
  • 1113 Answers
SOURCE: I need total reset for a Brother dcp 115c
Your print head is stuffed. More expensive than new machine, Release your frustration with this unit by placing neatly in bin!
The head drive voltage has
dropped from the high to
low level in an abnormally
short period.
Piezoelectric (PZT)
ceramic actuator
defective (Cracks or
rare short)
Posted on Feb 07, 2008
SOURCE: unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Posted on Jul 25, 2008
  • 115 Answers
SOURCE: brother dcp-115c driver download for windows xp 32
This is a link to the Brother website
You will need to select OS sys, Language etc
Posted on Oct 30, 2008
SOURCE: the error "CC025" appears [DCP-115C]
first uninstall the MFL Pro Suite & all the componants, shut down and restart system fresh install MFL Pro Suite fro the original CD supplied.
Posted on Jul 02, 2009
  • 265 Answers
SOURCE: dcp won't print
Try to clean the head several times.
Posted on Dec 11, 2009
Testimonial: "got black going cleaned it 12 times yesterday and 6 today and were printing black as soot."
0 characters
1 Points
I Suggest You To Watch Clear Error 46 Unable to Clean on Brother Printers Without Number Pad To Fix Your Brother Printer Issue,In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jan 21, 2014 | Brother DCP 115C All-In-One InkJet Printer
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
My printer DCP-115C show out the error code "Machine error 4F". How to solve it?
Unfortunately this is an error in print head and need replace.New print head will cost you as much more then new printer then think about new printer.
Nov 05, 2009 | Brother DCP 115C All-In-One InkJet Printer
Pc does not see the printer all usb ports on the board are working fine what is the problem
First install the Drivers for your printer in your PC and then connect it via usb cable. Hope your problem will be solved.
Apr 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp 150c problem
dear sir/maddam
i have printer Brother type DCP 150 C,
Now in the display show ERROR MC 48-49,
we can not sovling this problem,
please advice
Feb 10, 2009 | Brother DCP 115C All-In-One InkJet Printer
Dcp-115c usb cannot be found (CC027)
sure..some printers need to be plugged directly into wall socket for scanner to work..try that first..
Nov 21, 2008 | Brother DCP 115C All-In-One InkJet Printer
No driver brother dcp-115c
Here is driver download page, follow instructions, enter details and download the driver : Brother Solutions Center: DCP-115C: Others.
To install the driver do the following:
do the following.
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) your printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Sep 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C USB Printer
plz search this forum for error 46 or "unable to clean". It has been written many times ;-)
May 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
My printer have problem
you need a new waist ink absorber box.
Search this forum for error 46 or unable to clean. the procedure is explained many times (identical for all brother inkjets)
Apr 17, 2008 | Brother DCP 115C All-In-One InkJet Printer
Printers & Copiers Logo
93 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
