Philips GOGEAR SA6045  MP3 Player
Problem for Philips GOGEAR SA6045 (4 GB) MP3 Player
I have a GoGear device that won't charge
By dafonovan on Oct 03, 2007
Its a GoGear SA31xx and charges via usb, but when its plugged into my PC it just doesnt charge at all. It recognises its plugged in and i can upload stuff to it but the battery symbol stays on low and it won't stay on for more than a few seconds after its been unplugged. I tried resetting it but no luck... any ideas?
Clarification Request
Posted by saagoshroff on Aug 10, 2009
dont charge it through a computer.... get a seperate usb adapter which suits the go gear to charge n thn try chargin it ....
Same Problem
May 24, 2009
-   i have a gogear 2gb mp3 that won't charge. i plug it in and for hours and it appears to be charging but when i take it off and try to turn it on it won't. i've had mine for almost a year and it's worked great until now. what should i do, send it in? help! -   SugarRush85
Jul 06, 2008
-   wont charge. cant even turn device on. -   jolotazz
Mar 20, 2008
-   it wont charge
-   Guest
Mar 20, 2008
-   plugged into computor but won,t charge-   Guest
Nov 20, 2007
-   it keeps blinking saying philips-   hudson30
Solution #1
posted on Oct 22, 2007
Somewhat Helpful)
Quizling
Rank: Apprentice
Rating: 75%, 6 votes
Have you tried enabling the keypad lock? The slide for this can be seen on one edge of the player. See if this makes a difference.
Was this helpful?
Yes
No
Solution #2
posted on Dec 09, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i'm confused how do you enable the keypad lock, my brothes mp3 is doing the same thing
Solution #3
posted on Mar 30, 2009
Not Rated)
ragga43
Rank: Apprentice
Rating: 0%, 0 votes
Hi, I had the same problem with my SA31xx, when I plugged it into my PC it made the normal usb sounds and then a flash symbol appeared over the battery on the screen. It would not charge at all, I replaced the usb cable and it now works perfectly. Hope this helps.
Was this helpful?
Yes
No
Solution #4
posted on Jul 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my GoGear SA31XX shows backlight off even when its set to alwaya on...what do i do?
Solution #5
posted on Apr 19, 2008
Not Rated)
hatakekev
Rank: Apprentice
Rating: 94%, 5 votes
first start the computer then plug it in. get the lock of and if it then still not working then delete everything from ytour computer what has to do with your sa31xx . then re-install it and then look
Was this helpful?
Yes
No
Solution #6
posted on Dec 15, 2007
Not Rated)
kayylyynn
Rank: Apprentice
Rating: 0%, 0 votes
yes i have this problem too. when i plug the mp3 player in, it wont charge.
Was this helpful?
Yes
No
Popular Solutions for Philips GOGEAR SA6045 MP3
Questions and Unsolved Problems for Philips GOGEAR SA6045 MP3
Do you recommend Philips GOGEAR SA6045 (4 GB) MP3 Player?
Answer
Answer
i had my philips gogear for a little over two years now and it worked great until about two weeks... (More)
Answer
my Philips GoGear Mix 4GB will not play any music or radio. Media Engine Error is displayed on the... (More)
Answer
por que no puedo ver los videos en mi reproductor me dice que no es compatible
6 Other Users Have The Same Problem - Continued
Comment by DoctorGEE, posted on Nov 12, 2007
My Philips GoGear SA1335 (1GB) won't charge or be recognized when I plug it into the USB. What do I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips GOGEAR SA6045 MP3...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 441
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
