HP Pavilion dv9000t Notebook Logo
Posted on Apr 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP DV9000 motherboard replacement
I have a hp pavilion dv9000 with motherboard 444002-001 with the amd processor, Do I have to have the exact part number to replace or could I use one of the other amd motherboards for this model.
Thanks
Anonymous
Level 3:
  • Master 433 Answers
  • Posted on Apr 30, 2009
Anonymous
Master
Level 3:
Answers
433
Questions
0
Helped
210414
Points
1339
Motherboards are part number specific. Please make sure that the part number you order matches the part number of the Motherboard you are replacing
I think I would use the exact one called for.
Does anyone know where to get the schematic for the dv6550us motherboard?
The closest I come to an HP Pavilion dv6550us, on HP Support, or on the internet is;
Pavilion dv6550tx
Next inline is Pavilion dv6560us,
then Pavilion dv6450us
Not available to the public.
Do have a Block Diagram,
Models that use an AMD processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV9000-AMD-Notebook-Laptop-Quanta-AT8-Schematic.jpg
1) Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
2) Motherboard chipset is an Nvidia MCP51M
Which is the mobile version of Nvidia GeForce Go 6100, or Go 6150;
and Nvidia nForce 430,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_Go_6_.28Go_6xxx.29_Series
Graphics chipset,
http://www.ebay.com/itm/NEW-Original-nVIDIA-Geforce-NF-G6150-N-A2-BGA-ic-chip-north-bridge-Chipset-/271010886762?pt=LH_DefaultDomain_0&hash=item3f1981f46a
Conexant CX20549-12 audio chipset
Realtek RTL8101C Ethernet chipset
Models that use an Intel processor,
http://www.laptops-schematics.com/wp-content/uploads/2011/07/HP-Pavilion-DV6700-Intel-Notebook-Laptop-Quanta-AT3-Schematic.jpg
Uses the Socket P processor socket,
http://en.wikipedia.org/wiki/Socket_P
Both use the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, and Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET, in the DC - DC circuit; as far as I know.
Both are Obsolete, but there are cross match examples out there.
(FDS6679AZ for FDS6679, for one)
Indicates HP Pavilion dv9000 series, and AMD; but also matches up to the Pavilion dv6500 series,
http://www.scribd.com/doc/89356925/HP-DV9000
Scroll down. (Zoom In icon { + } at TOP to increase view size,
Zoom Out icon { - } to decrease view size )
Asking for a Schematic, do I assume you are attempting
Board Level Component replacement?
What SMD/SMT IC component are you trying to replace?
(Surface Mount Device/Surface Mount Technology. Integrated Circuit)
Motherboard chipset info, and processor socket info, for processor upgrade.
Same thing for Ram Memory upgrade.
It does use DDR2 Sdram (SO-DIMM), and at 667MegaHertz, to my knowledge.
What usually goes bad on the HP Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's?
The cooling for the graphics chipset is inadequate, therefore the graphics chipset overheats, and partially melts the Solder Joints in the BGA surface mount.
Resulting in no graphics.
Power MOSFET's in DC - DC circuit go bad.
Continued in Comment
Difference between DV6000 Intel mothearbord and DV 6000 AMD motherboard
The DV6000 is a moniker for an entire series of laprop computers, each with a unique model number that has some variation the DV6XXX. Some will have Intel Core Duo, some Intel Celeron, some AMD Turion 64, and some AMD Mobile Sempron processors. Features, speed, and cost will vary appropriately with the Obviously the AMD and Intel boards are different and you cannot swap processors between boards. Here is a link to the HP Maintenance Manual for the DV6000 series laptops. It lists all the Mainboards used with the series and what processors go on them. It is useful for ordering replacement parts and gives instruction on disassembly and repair.
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
Is there an upgrade CPU available for the HP Pavilion a1410n PC
Here is what your motherboard can handle:
Supports the following processors:
AMD Athlon 64 X2 up to 4800+
AMD Athlon 64
AMD Sempron
Reference: HP Pavillion a1410n
See Product Information>Product Specifications>Motherboard Specifications
Thanks for using Fixya.
It's a motherboard....dv9000 AMD
There are several solution already in Fixya, just do a search to find some helpful tips and some bad news
Motherboard is dead, need to replace.
There again I would stick with the motherboard that is called for, you'll find it fits and you will not have a difficulty finding drivers that play nicely together. I have see a lot of remanufactured on eBay and parts places, you might save money that way.
please leave rating, thank you
2helpful
2answers
HP Pavilion Entertainment PC dv9000
Making a fairly confident presumption that your laptop is an AMD-based unit, model is....DV9205, DV9310, or DV9410
HP issued a service alert 07122001 covering such AMD-based laptops with your wifi failure, as well as additional failures within your product line. This is a warranty enhancement that will cover the replacement part and labor for you the customer.
HP has very recently started phasing out their older models like the 9005/9010, as the issue alert is basically good from 2yrs of date of purchase.
2 solutions for you....
1) Call HP and give them the serial/model info and inquire about that service alert # mentioned above, see if your laptop is still covered.
2) Replace the motherboard yourself and at your cost
(ok maybe another option)
3) Get a USB wifi card :/
-Sy
HP a220n (midtower PC) replacement
Duane , a good AMD 64 x2 Duel core processor motherboard would be the Asus M2A-VM AMD Socket AM2 MicroATX Motherboard / Audio / Video / DVI / PCI Express / Gigabit LAN / USB 2.0 / Serial ATA / RAID this motherboard will fit in your midtower. It comes with firewire and usb ports. hope this helps.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
