Question about Canon PowerShot A410 Digital Camera
Card locked While switching on, I am getting msg of "CARD LOCKED" which is not allowing me to operate the camera.
  • 4 more comments
  • lrivers Nov 08, 2007
    cason a410 camera have memory card and when i put it in it states card locked and then memory card error on it. what do i do to get it to worked.
    The slide on the side unlocked.
  • MssAnntt Nov 22, 2007
    I have a Canon PowerShot A410 digital camera, I have been using it just fine until recently and now when I turn it on I get a message Card Locked!!
    Unable to take pictures. How can I get this to go away.
    Please advice. Thanks
  • KGJune21 Jan 08, 2008
    i have Canon powershot A450 digital cam. Whenever i turned ON it says CARD LOCKED. What should i do? I can able to see my previous photos from the memory card but not able to take new photos. Pl. suggest something!!
  • nuzzu Mar 15, 2008
    my 1gb memory card has been locked i can see my previous pictures but i cannot take any new pictures from my camera when i switch on the camera it showing that card locked.
  • Anonymous Mar 21, 2008
    card locked
  • nuzzu May 11, 2010
    i have a canon power shot A450 3.2 optical zoom 5.0 megapixels when i switch on it showing "CARD LOCKED" now what should i do now please help me and give me a new solution and suggestion.
    Problem Solver:
  • 14 Answers
Make sure the lock isn't on, on the memory card itself.
All SD cards have a lock function on them which keeps any changes from being made to the data that is stored within it.
If you look closely you will see a very small switch on the side of the SD card. Try switching it to the opposite direction and then try to take a picture. If it works then that was your problem all along.
If it doesn't, try switching it back just to make sure.
If you find that neither side works you may want to buy or borrow another memory card to make sure its not a problem with the camera.
Post back if the problem is still their and I will advise further.
Good Luck!
Posted on Feb 19, 2008
You rock man, even though im feelin a lil dumb now since i have had my cam for three years and dint even know about that feature on my sd cards...lol
tyvm =)
Posted on Jun 24, 2008
SOURCE:
Screen read card locked ,will not allow to read cardunlock sd card
All SD cards has a physical switch that locks the card. Remove the card from the camera and check this switch. It's on the left side of the card opposite side the angled edge. Make sure that the switch is in the forward position (towards the pins that get seated in the camera). Replace the card in the camera carefully to avoid moving the switch. Try accessing the card again.
If the switch is damaged or slides back and forth to the locked position easily, replace the card. It's possible to temporarily fix the card to access it. You need to carefully cut the switch plastic away from that slot and then cover the slot with tape. Make sure that the tape lies flat against the card and doesn't cover the area with the pins.
I hope this helps.
Apr 27, 2014 | Samsung BL103 Digital Camera
Tip
Memory card locked
This is a tip explaining the error, "Memory card locked". We will also give you the resolution for this error. This error, or rather message, is usually the result of the following situations.
Situation 1:
Well, this is usually the problem, on the memory card, there is a little switch on the left side, which can switch between "Lock" or "Unlock".
If you get the display, memory card locked, remove the card from your camera, or USB adapter and have a look at the switch, if it is switched to locked, move the lever top the other side and place it back. This should solve your problem, if not, lets have a look at situation 2.
Situation 2:
Open the card slot of your camera and have a look inside with a bright light/ torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch.
With time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
I really hope this can steer you in the right direction. Please rate accordingly.
Kind regards
Andrea
on Feb 27, 2010 | BenQ DC C740i Digital Camera
My nikkon camera is saying memory card is write protected when it is on unlock. PLEASE HELP.
Try the card in a different camera, and try a different card in your camera, to try to isolate the problem.
Locking of an SD card is by the little plastic slide which operates a switch in the camera itself. The slide must be present in the "unlock" position, to operate the switch, to allow writing to the card; therefore if the slide is missing, the camera considers the card locked.
Jan 19, 2011 | Cameras
I have a Canon Power Shot SD790Is DIGITAL ELPH and the camera keeps saying card error, card locked. I am aware there is a switch on the side of the card, and it is currently unlocked. When I turn the...
Hello
Ok, here is something you can try:
In your case the problem is not with the card but rather with your camera's card reader. This is a rather hard problem to fix yourself but here is what you can do.
Open the card slot of your camera and peer inside with a sharp light or torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch. Contrary to popular belief , the switch on the card does not impact the operation of the card itself but rather tells the camera that the card should be locked by depressing the little pin inside.
If you put a protected card into a camera with no protection switch , the card would operate normally.
However , with time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
Kind Regards
Andrea
Aug 03, 2010 | Cameras
Locked card
Hello
Kind Regards
Andrea
Aug 03, 2010 | SanDisk 2GB microSD Memory Card
Memory card locked
Hello
Kind Regards
Andrea
Jan 17, 2010 | Canon PowerShot G9 Digital Camera
Cannon sd1100, getting card locked message on camera but the sd card is not locked. I have tried other sd cards with the same issue.
Hello Wingerc
Kind Regards
Andrea
Dec 27, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Msg when I click a picture on my S860 "Card Locked!" How do I fix that?
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Dec 12, 2009 | Samsung S860 Digital Camera
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Apr 26, 2009 | Pentax *ist D Digital Camera
Camera is card is locked
Check to make sure that the card is not locked. There should be a small switch to say lock so if the switch is on it the switch it.
Apr 24, 2008 | Cameras
Canon PowerShot A410 Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
