Question about Sony Ericsson P990i Smartphone
P990i is not supporting headset bluetooth HBH-PV700
My mobile P990i is not able to find bluetooth headset HBH-PV700. Although it can detect other bluetooth mobiles. How can i resolve this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
You must operate your bluetooth headset HBH-PV700 in discovery mode in order for your mobile to discover the headset and then pair the two devices. To activate the discovery mode of your headset, while it is switched OFF press the switch on button and leave it pressed for approximately 10 seconds, then search for it with your mobile and pair the devices. most of the times the code needed for pairing is 0000 (zeros)
Posted on Oct 08, 2007
SOURCE:
Pair my Sony Ericsson bluetooth HBH-PV703 with Pantech Impact cell phone
You must put your headset in pairing mode first. Starting with it turned off, press and hold the call handling key until the indicator light flashes alternately in red and blue. Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode, and there should be some indications on your phone too.
The pairing process between any two bluetooth enabled devices should be done only once. All subsequent connections should be achieved by turning both your headset and your phone's bluetooth radio on and bringing them both into each other's range. At most, a single press on the headset's call handling key should do.
Hope it works for you.
By the way, if your headset's user guide seems to be missing, feel free to download it from this location.
Please, let me know if you need further informations.
Regards, Carlos
Sep 25, 2010 | Sony Ericsson Genuine Bluetooth Headset...
How do i activate the HBH-IV835
Here's a little tutorial:
http://www.sonyericsson.com/cws/support/accessories/detailed/learnaboutbluetoothaccessories/hbh-iv835?lc=en&cc=ca
Hope that helps!
Nov 07, 2009 | Sony Ericsson HBH-IV835 Bluetooth Headset...
N97 connectivity problem with bluetooth HBH DS 200
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Sep 08, 2009 | Sony Ericsson HBH-DS200 Stereo Bluetooth...
Can't connect with my n97 (or other Nokia phones). The phone doesn't detect the HBH-IV835.
Read the manual of the HBH-IV835.
Page 15 "Prepare the headset".
This solved the problem!
Aug 25, 2009 | Sony Ericsson HBH-IV835 Bluetooth Headset...
HOW TO START TO SET MY BLUE TOOTH IS CONNECTED BY THE LITTLE ICON IN THE TOP CORNER OF MY PHONE BUT WHEN I RING IT IT IS JUST GOING ON TO MY PHONE. EVERY TIME I SEARCH FOR THE BLUETOOTH IT KEEPS SAYING...
switch on your bluetooth and press the push button until the led stops blinking.
now you can go to the bluetooth application on your mobile phone and search the HBH-PV700 .
Aug 11, 2008 | Ericsson Cell Phones
HOW DO I TURN ON MY SONY ERICSSON HBH PV700 BLUETOOTH?
Figured out the problem, If you hold the Volume + and - buttons for 5+ seconds, The blue tooth will go into Search mode and flash green and red, This will allow you to connect it to new devices, If it was already connected to a previous device everytime you turn it on its searching for the older device, You have to pair it with the newer device
Mar 31, 2008 | Sony Ericsson Genuine Bluetooth Headset...
Accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Sep 17, 2007 | Nokia 6300 Cellular Phone
Sony Ericsson P990i Smartphone Logo
168 people viewed this question
Top Sony Ericsson Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
