160 Gig harddrive installation problem
I have a 40 gig harddrive and i want to install the new 160gig harddrive but my PC does not recognise it.
  • Anda_agE Oct 04, 2007
    Ur solution was right on de money.....much thanx 2 every1 @ fixYa...
  • jimmygreen Nov 18, 2007
    Connected drive to USB port - System reports USB Device Not Recognised. One of the USB devices attached to this computer has malfunctioned, and windows does not recognise it.......
  • 4 Answers
I don’t get a drive letter or an icon in My Computer for the drive even though it’s plugged in. How can I fix this?
If you have other drives installed on the system, Windows may try to install the Ultra TravelDrive with an existing
drive letter. This issue can happen in Windows 2000 and Windows XP. To correct this, follow these steps (You
must have administrative level access.):
a. Go to Control Panel.
b. Click on Administrative Tools.
c. Click on Computer Management.
d. Click on Disk Management.
e. In the drive listings, you will see the Ultra TravelDrive with its rated capacity. Right click on it.
f. Click on Change Drive Letter and Paths.
g. Click Change.
h. Click on the down arrow and select an available drive letter (We suggest “T” for TravelDrive.).
i. Press OK twice.
j. Close Computer Management and Control Panel.
You should now be able to see the drive correctly in Windows Explorer or My Computer.
Posted on Sep 24, 2008
  • 363 Answers
Is it being recognised in bios? If it is then you might need to partition it for windows to see it properly. You can do this in the disc manager (right click my computer > Manage) Hope this helps
Posted on Oct 03, 2007
I bought this HP Pavilion a1610n and it had a dead 250 gig sata harddrive(western digital).I installed a new 250 gig harddrive western digital sata drive in this computer(motherboard is a A7VBX-LA)I cannot...
Here are the original drivers for Xp on top and Vista on bottom not sure which you have or need.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3239117
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3239117
Sep 14, 2011 | HP Pavilion a1610n PC Desktop
I have a hp4345mfp on the display it is showing a error internal disk not found we do not have a hard drive can we turn off the hard drive thank you my email is
All HP MFP's have an internal harddrive and will only function as printers if that drive fails. You need to replace the harddrive. It is mounted on the formatterwhich is accessed on the back. First remove the sliding panel and then open the metal door. These are right where the fax and data cables plug in. You can replace the drive with almost any 2.5" IDE harddrive that you can find. The standard model will be either a 20, 30 or 40 gig, I have installed up to 160 gig drives with no problem. Do not order a drive from HP as they will charge several hundred dollars for a drive you should be able to get at any computer shop for less than $75.00. Be cautious removing the drive from the plastic mounts as they are easy to break.
May 17, 2011 | HP LaserJet 4345mfp Printer
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Aug 17, 2009 | Computers & Internet
Having major problems installing windows XP
Your motherboard has a bad on board hardware. Its hard to fix that eventhough you disable the function on it. Its better to buy a new motherboard.
Jul 24, 2009 | Microsoft Windows XP Professional Edition...
Gateway solo 40 gig will it work in tshiba laptop a45-s150
Yes you can, but most likely it will not work (you have to format it and install fresh copy of Windows (or Linux)).
Mar 28, 2009 | Gateway Solo 9300 Notebook
Want to upgrade memory
maximum memory is1GB for your motherboard, you can only install 2 x 512MB, sorry.
Refer to this page: Hp site
Alex
Mar 26, 2009 | Computers & Internet
I have two dell computers. A dell Optima GX270 with an 80 Gig harddrive (that is my primary business computer) and a Dimension E310 P4 with an 80 Gig harddrive with a hidden reserve harddrive. The Optima...
To know which is which all you need to is look on the harddrive to the back where the jacks go when you remove the jacks you will see a little plastic jack on two pins you can remove the jack to make the harddrive reserve once you remove this jack the hardddrive is know longer the main one.If you any problems please let me know thank you. (rate me)
Jan 13, 2009 | Dell Dimension E310 PC Desktop
My sony vaio s460 does not detect the hardrive, after I installed new 120 gig sata, I called to sony and they said tha I need the same hardrive 80m gig 5400 rpm, as the laptop comes from factory, it is...
It may be that your machine can not handle a drive of that size. When I replace hard drives I always try to replace them with the size they came with just in case they do not support a larger size.
Dec 18, 2008 | Sony VAIO VGN-S460 Notebook
Arcsoft software for Nikon 5400 camera & monitor flickers
take the old drive out, copy what you have on it to the new drive beforehand, then remove it and you will have a working backup of your data in case something goes wrong. If you still using old drive as system boot partition you can use Norton Ghost for example to transfer the system, download a free trial from norton website and go from there. But best would be add at least 256mb more RAM as this speeds up your system and reinstall windows and all your software from scratch onto new hard drive, it will be more reliable and significantly faster.
Jun 19, 2008 | Nikon Coolpix 5400 Digital Camera
How to make Vista to recognize my old Hard drive
There are normally only two ways to get vista to recognise large drives and that is to format it within windows by way of right click my computer then click manage and then highlight your harddrive right click and select format. The other way is if your drive isnt being recognised because of the bios and needs updating, as most bios chips did when upgrading to vista.
Jun 18, 2007 | Microsoft Windows Vista Business DVD...
Computers & Internet Logo
319 people viewed this question
Alun Cox
David Payne
David Payne
