Question about Philips 32PW6006 32" TV
Philips 32" CRT problem
Hi guys, Problem is when I switch on the set it takes about 30 sec to give picture and sound. It takes about the same time to change channels or to make an adjustment to volume. This is both with remote and manual. When I eventually get it to change over to digital everything works fine ... Anu ideas ?
  • pherlo Oct 03, 2007
    Thanks likha,
    I have some experience with SMT ... Would this be a DIY job ? I have never opened a TV set before !
    Should I leave it to the professionals ?
  • 790 Answers
You have defective starting capacitor! at the hot side!
Posted on Oct 03, 2007
Black box on screen
Without a picture of it it's hard to say what you mean. Sometimes on a CRT TV the vertical scan doesn't fill the screen, but that would cause a black band both top and bottom. The usual cause is a capacitor drying out. But only a qualified tech should look into that.
Jan 04, 2014 | Philips Magnavox TS3260C 32" TV
Model KV35540 Series #9017817 goes to standby after 30 sec
OLD set, most likely the picture tube has aged and only hope would be if the master screen inside the set is turned up just a little it may function again. If doing that (taking back off) be careful and also look in neck of the picture tube to see if the 3 filaments are faintly lit.
Only chances are no filaments or screen set too low from old age.
Nov 01, 2012 | Televison & Video
When I turn the set on green leds appear for about 30 sec then it swicthes to red stanby and flashes 5 times intermitently
May I know what is the exact model number of your TV, it is located at the rear cover, manual, and on the receipt. It will help diagnose accurately where the fault came from and confirm the blinking error code.
Jan 11, 2012 | Televison & Video
Turn t.v. on, stays on for 30 sec., then shuts off.
While the set is on does the picture and sound come on well, If so the fault is relative to the output stages, look for components heating up, dry soldering due to this heat cutting off the connection.
However if there is no picture or sound then the fault is in the processor , a test on voltages on diffferent cicuits must be checked when the set shuts down. This will indicate the defficient voltage , possible in the power or output board.
Sep 16, 2010 | Philips Magnavox 27MS343S 27" TV
Tv no pic or sound
If you hear the high voltage try to come up and set shuts down in 2 secs it could be your FBT also these sets have alot of poor connections chassis should be resolder.
Apr 06, 2008 | Televison & Video
Television reverting to standby
Hi Phil.
Try adjusting A1 on loptx it is very critical & can cause the symptoms you are describing.
You could be right in saying the crt, Philips tubes are notorius for failing.
Im hoping your a tv tech if you are not DO Not do what I have written below tapping neck to hard can cause seriouse injury to your self.
Run set & tap the glass neck of crt if pic flickers or you see red blue or green flashing while tapping tube neck it will be the tube.
Let me know results there are a few things that can be done.
Dec 15, 2007 | Philips 32PW6006 32" TV
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Phillips 30" Mod 30pw633r37a
I unplugged it for 24 hours. When I plugged it back in it was ok. It has done it a couple of times since, but only for a few seconds.
Sep 02, 2006 | Philips 32PW8608 32" TV
Philips 32PW6006 32" TV Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
