Question about Dishwashers
Whirlpool dishwasher Model DU9450XY-1
I just purchased this dishwasher used. Had a friend help me install it. The dishwasher seems to fill with water then slowing empties on to floor for the underneath center part of the unit.
  • Brnigrl Oct 04, 2007
    the leak is coming from the very middle of the bottom. After the tub fills with water is seams to slowly drip from center.
  • 447 Answers
It may have a cracked tub does it drip out of the tub brace (a strip of metal that runs side to side on the bottom of the tub behind the wash motor) Have replaced several for this issue. Have fixed them with good epoxy also. PLEASE rate my help as solved if i answered your question!! Thankx
Posted on Oct 03, 2007
SOURCE:
Whirlpool dishwasher just keeps filling? help please
check on the floor of the dishwasher on front left side. There should be a round float that is the overflow cut off. \make sure that it will go up and down. This is what shuts off the water.
Mar 07, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishes are not clean in my whirlpool gold quite partner III. my model #gu2275xtvy0
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Whirlpool Dishwashers
I have brand new whirlpool ADG7561 that has only been used a few times, without issue and it now will not start the cycle properly. It seems to start and can hear water filling then after a few minutes it...
Brynn_parson:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 06, 2018 | Whirlpool ADG 7561 Dishwasher
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
Dishwasher won't start!
I've provided a link to the manual for your dishwasher. You should check for proper wiring and that the water line is connected and turned on.
The washer should start to fill when you press a cycle.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208283509.pdf
May 09, 2009 | Dishwashers
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
129 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
