Question about Canon EOS-20D Digital Camera
EOS 20D - LCD dead??
Hi to all! Sorry my englisch is not perfect I'm from Italy! Got a big problem with the LCD-Monitor of my Canon EOS 20d. The Monitor is completely dead, the camera itself works as ever. Had some custom functions working as the LCD went out, then it came back for some minutes and I immediately removed them (for example mirror up), so now I can normally take pictures. But as I do a lot of Macro I need the "Mirror Up" Custom Function. Now the LCD is completely dead and always black. When I press the "Menu"-Button or "Play", nothing happens and the LCD remains black. Maybe this happened because I tried a lens of a friend of mine, a Voightlaender for EOS, and now there is a short circuit or something. Hope there is an easy solution as in 3 weeks time I'm heading to Florida for vacation and I always shot an enourmos amount of fotos! Please help!!! Thanx
  • Vandexter Oct 03, 2007
    Hi Poolseman!
    Thanx a lot for your immediate answer! So I think I'm gonna buy a new one immediately and send the old one to the Canon Center nearby!
    Greetings Tommy
What is a 'relatively expensive repair' can you estimate a range for me. I have a similar problem - should I send the camera right to Canon or can others fix it?
Posted on Dec 23, 2007
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
So far this year we have repaired 4 Canon 20D's with this problem and it always is either the Main PCB ( the interface IC which controls the main display and which sits on the main board shuts down ) or the LCD monitor that have to be replaced so your camera has to go to Canon I am afraid ( ask for a quote as this is a relatively expensive repair ). The fault BTW cannot be caused by using non Canon lenses.
Posted on Oct 03, 2007
SOURCE:
Error code 99
Hello, if you have problems with your canon eos 20d you can download the service manual from the below link you will find there useful information like disassembly, troublehooting, repair
Canon EOS 20D Service Manual Download link:
http://goo.gl/EIsEb
Good luck.
Apr 04, 2012 | Canon EOS 20Da Digital Camera
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
The shutter continues to click in rapid concession Canon 20d
Check to make sure that you don't have it set on continuous. Check the lcd display and see if the shutter icon showing a mulitple as opposed to single frame image.
You should be able to choose between single, mulitiple and timed shutter releases...
Sep 08, 2009 | Canon EOS-20D Body only Digital Camera
Canon EOS 20D Digital zoom failed
The autofocus mechanism on some lenses can be damaged if you manually focus while the camera is attempting to autofocus. Basically, you would be working against the motor and gears.
There is no need to download software before using the camera, however, I would suggest going to Canon's website and downloading the firmware upgrades for it. Here's the link:
Canon 20D Firmware Download
Hope this helps!
Oct 12, 2008 | Canon EOS 20Da Digital Camera
EOs 20D digital camera
Prior to models made in 2007 or later, no SLR camera (film or digital) was able to let you compose the picture before shooting it other than through the optical viewfinder. SLRs are different in this respect from compact digital cameras. You will only be able to review your pictures on the LCD after they are taken.
Jul 29, 2008 | Canon EOS-20D Digital Camera
My Canon EOS 20D has a problem
could be that you have dust / dirt on the sensor even when mine was brand new it had dirt on it.
Jan 27, 2008 | Canon EOS 20Da Digital Camera
Connection Problem
I too have a Canon 20D and receive the same message. Zoombrowser works fine with my Canon G3, so the way I get around this problem is by using the other software that came with the 20D called EOS Viewer. This software will download your images every time. You might try sending a note to Canon's support team on the Canon website. They are very quick to respond to all questions and they can probably respond to this question too. Good luck!
Aug 31, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Canon EOS-20D Digital Camera Logo
250 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
