Metra TurboWires 70-6509 for Jeep Grand Cherokee 199 Logo
A
Aaron Badding Posted on Nov 05, 2013
Replace timing chain on 99 jeep 4.0
I need to replace the timing chain on my jeep and need to know how
iwandra cuy
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 06, 2013
iwandra cuy
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
369
Points
7
Kau yang membuat aku bertahan dalam senyuman tapi kau juga yang membuat akub terperangkap dalam kesakitan
4 wheel drive wont lock in on my 99 jeep cherokee.is there vacuum
are you on pavement, or offroad.?
99 Cherokee what transfer case?
if Part time system. then,.
are your tires on ice or dirt?
if not its cockpit error.
read the operators guide, on this.
if on ICE,say so, we can not know what transfer case you have
nor what tires are sitting on.
do tell, and we can tell you what good or bad.
here is the build list for these years XJ
what do you have. ?
The full time box, must not be in 4Lo , on pavement
unless it too is on ice .
All the transfer cases used on the Cherokee were chain driven with aluminium housings. Command-Trac was standard on XJ models built with 4WD.
  • 1984-1987: New Process NP207 Command-Trac, part-time only, 2.61:1 ratio with low range
  • 1984-1986: New Process NP228/229 Selec-Trac, full- or part-time, 2.61:1 ratio with low range
NP228/229 has a vacuum switch for 2WD-4WD selection on the fly and a separate manual lever for low range
  • 1987-2001: New Process NP231 Command-Trac, part-time only, 2.72:1 ratio with low range
NP231 has the following settings: 2HI, 4HI, N, 4LO
  • 1987-2001: New Process NP242 Selec-Trac, full-time or part-time, 2.72:1 ratio with low range
NP242 has the following settings: 2HI, 4 full-time, 4 part-time, N, 4LO
never post questions on 4wd unless you know what is there.
the transfer case, also has tag , telling what it is.
1helpful
How do i know if my 95 jeep grand cherokee laredo 4.0 inline 6 is an interference engine
You have a timing chain that is good for the life of the engine. The only thing that could need replacing is the chain tensioner if it starts to make noise.
1helpful
Need diagram to install timing chain on 99 jeep grand cherokee laredo
Hi there;
Just rotate the crankshaft so that the timing marks are aligned...
FIG : Timing chain alignment marks - 2.5L and 4.0L engines
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
2helpful
2answers
At what mileage does the timing chain need to be replaced? jeep wrangler 2008,3.8 L 6 cil.80,000 miles
You change the timing chain now when your Jeep has indicated from a check engine light on. The timing chain in engines these days last as long as the engine will, there is a timing chain tensioner to ensure there is no slack.
When the timing chain has gotten stretched to much, your Jeeps PCM will indicate that with a check engine light on your dash and will be indicated with a DTC codes from a scanner.
So no worries about replacing your timing chain and keep up the regular maintenance, if you have a Mechanic tell you other wise, there just looking for money and your looking for more then just a timing chain being replaced.
You can bet that chain, chain tensioner, timing gears, water pump and might even throw in a cam replacement will be in his recommendation.
Thank you for using fixya and be safe.
How to repair fuel injector and timeing chain
get a haynes manual at a discount place or search online
2helpful
Do you need to change the timing chain on a 2003 Jeep Grand Cherokee at 75,000 miles?
You will not need to change a timing chain unless you know or suspect it to be bad. Belts and other material that wear down need to be changed but the timing chain itself is a metal similar to that of a bike chain but much shorter and thicker
Timing chain set up
hi there if you already replaced the timing chain then you must have aligned the crankshaft mark to the mark that is on the cam sprocket ?
Top Metra Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Metra Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
