Question about Zenith R49W36 49" Rear Projection HDTV
Snap, crackle, pop
When plugged in there is no picture, after about 30sec hdtv led comes on. television makes electrical noises? any idea about what the problem might be? Is this fixable by a novice?
  • Anonymous Mar 27, 2008
    same problem when tv is pluged in the screen is black HDTV lights up blue sparks and arch noise comes from rear of set then the tv powers off.
  • 790 Answers
No you need a qualified technician! you have defective power supply in oscillation circuit... and i think thats capacitor.
Posted on Oct 03, 2007
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
No picture (black screen); making popping/crackling sound
there is a possibility that the semiconductor in power supply side damaged due to electrical surge. more likely the STR IC of Diodes.
Jun 01, 2009 | RCA P61960 61" Rear Projection Television
Tv has sound but no picture
my rca hd model hd50lpw164 has no picture. some sound and a electrical popping noise.
supect the lamp is out.
where can i obtain new lamp and whats the cost.?
Nov 20, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Zenith R49W36 49" Rear Projection HDTV Logo
85 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
