Question about D-Link AirPlus DI-614+ Wireless Router
NAT Options Right now my NAT settings are set to strict, and I'm unaware of how to change it from strict to open, if you can assist me that'd be wonderful.
  • Anonymous Nov 03, 2007
    Same problem...Belkin N wireless router, static ip, nat enabled but strict.
    Need to make it open. any ideas
    Scholar:
  • 193 Answers
Is teh ip assigned static on teh pc or in the router
if its in teh router then login to the router and home and click on wan and change it to Dynamic IP Address and click on apply and reboot thats it if its working rate me solved
Posted on Oct 14, 2007
  • ramji duraiswamy Oct 17, 2007
    connect a pc directly to the one of teh ether net jack on teh router>and open a browser like inter net explorer>and type 192.168.0.1 and enter>and user name admin and password admin all lower case>and hit login proballey the user name or password may different if u find dificulty to do this look @ teh back of the router and u can see a small hole color in red says reset>turn on router and take a pin or papper clip and press it and hold it for 40 sec and relese and turn off router and wait 30 sec and turn on it this will automatically make the router dynamacially try this
  • ramji duraiswamy Oct 18, 2007
    have u tried this is it working and rate me solved if its working
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
Ihave a strict nat cant change to open nat i dont have the skills to do it or understand how
This is a good site to have a look at for nat problems, click on the link, www.noddegamra.co.uk/problems-with-xbox-360-live-nat-settings/3
If this helps thumbs up, if not, comment for further assistance.
Mar 01, 2010 | Microsoft Xbox 360 Console
Dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
Jan 04, 2010 | NetGear DGN2000-100NAS Router
Bt home hub change my nat from strict to open
reduce the MTU. If the MTU settings is1500 then change 1365.
Nov 22, 2009 | Computers & Internet
I need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Need to make NAT settings to open for xbox live.
Open up your internet explorer then go to tools then internet options then make the changes nessessary i would recommend you go to google on what to change specificly
Mar 23, 2009 | Arris SBG1000 Wireless Cable Modem Gateway...
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Strict nat settings
go to security tab on the router interface and deselect NAT button.
Jul 03, 2008 | NetGear WGT624 Wireless Router
Set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Jan 19, 2008 | Zyxel Prestige 660HW Wireless Router...
D-Link AirPlus DI-614+ Wireless Router Logo
380 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
