FixYa.com
Tags:
Film Cameras
Generic problem for all Film Cameras
Super Ikonta 530/2 B Speed setting not working. ...
posted by Ikontauser on Oct 03, 2007
Have removed front amd cleaned lens front and back including front middle lens. Cannot clean back of middle lens due to B shutter speed not working. All other shutter speeds appear to work fine. Remove front name ring, focus prism plate and clean gearing, oiling and greasing for coupled range finder. Every thing appears to work fine. Have begun to remove top plate. All parts needing removeing have been done excepting film winding pin. Seems to be somewhat different from David Richert site repairs. No pin as such. Just a screw which doesn't want to come out before I can remove top. Rangefinder rear sight glass remove. Am at a stand still.
How can I get the shutter to open on the B shutter setting to get to the back of the middle glass. All other shutter speeds, including 1 sec. and rangefinder appears to work properly.
Once top off, how do I proceed to replace the mirror in viewfinder. Inside are appears to need cleaning. Couldn't find instructions on Internet. Any and all help would be greatly appreciated. Anxious to use camera.
Comment by Ikontauser, posted on Oct 03, 2007
Does anyone know where I can find an English version of a repair manual for this camera?
Will Post a Dig. photo if necessary. However someone with this tech. knowledge probably will not need one.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 13, 2007
Thanks for Trying (70)
eagle338
Rank:Wiz Wiz
Rating: 80%, 905 votes
If you want a manual you can get it here
http://www.oldtimercameras.com/londoncameraexchange/stock/Model.asp?Model=13796&ModelPage=true
Read this and since its a simple problem you will get all you want to know!
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Canon Elph LT 260 APS Point and Shoot Camera Canon Sure Shot 80 Tele/Date 35mm Point and Shoot Camera Canon Sure Shot 90U 35mm Point and Shoot Camera Canon Sure Shot 105u 35mm Film Camera Canon Sure Shot 65 35mm Point and Shoot Camera Canon EOS Rebel XS 35mm SLR Camera Canon EOS Rebel G 35mm SLR Camera
Can you Help with these Film Cameras problems?
Konica U-Mini AF 35mm Point and Shoot Camera
Konica Zoom FR735 Camera
I have a Konica Zoom FR735... Answer This...
Minolta Vectis Weathermatic Dual 35mm Point...
problem with Minolta Vectis...
I had recently loaded a new... Answer This...
Film Cameras
Minolta Dynax 500si displays...
My European model Minolta Dynax... Answer This...
Minolta X-700 35mm SLR Camera
Silly question re manual...
Just got hold of X-700 and can... Answer This...
Nikon Lite Touch Zoom 140 ED/QD 35mm Point...
Display lights
when the camera is powered on... Answer This...
Repair Service
Find Film Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
