Question about IBM ThinkPad A21m 2628 Notebook
Installing new OS
Im installing new OS on my IBM A21m laptop but when installing it always shutdown.I already formatted the hard disk using windows xp installer but when im installing my laptop is always shutdown.When i turn on the cpu fan is working and after several minutes it goes down.How can I install the new OS if it always shutdown?Where I can find the temp setting of cpu?Pls advise.Thank you
    Novelist:
    Scholar:
  • 167 Answers
Every laptop is accompanied by a preinstalled vesion of Windows, on the same hard disk in a hidden space. So if you get a prompt to restore your laptop to a previous state at the beginning of system startup, press the relevant key. If windows xp is your choice. and want to install it you may need follow the installation instruction from your system manufacturer. When the system starts up some information is displayed on the screen, like this: " Press F1 to enter setup" If you press the relevant key and enter the BIOS setup you can find the CPU temperature settings, shutdown temperature etc... This may not be you case. So I suggest you to get support from a qulified technician. Your system hardware should have some problem. (motherboard or hard disk is more prone to error) you can also try to find information from your system vendor's manuals and support website. All the best
Posted on Oct 03, 2007
SOURCE:
Clear documents on 1998 ibm thinkpad
If you mean wiping your hard disk clean and installing Windows again then -
Installing Windows XP
This is generally how your format the hard disk and install Windows.
First you need a Windows XP installation CD and the product installation code, which is printed on the Windows label on the bottom of your laptop.
Boot up with the Windows installation CD start and follow the instructions to install Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quick format. This will prepare the Windows for a clean install.
Next create a Username and company name (normally Home is all you need).
Further into the installation, you will be required to put in the Installation code. During the final stages of installation you need to create an User or Users that will use this computer. When you finished installing Windows you need to install the laptop's device drivers. You need to use a computer with Internet access to download these drivers from the laptop manufacturer's WEB site and install these drivers on your laptop.
Next connect a LAN cable to the LAN port from your computer to your DSL or cable modem and you need to Activate the Windows installation on the Microsoft WEB site.
Next up need to upgrade Windows from the Microsoft WEB site including Service pack.
Oct 21, 2012 | IBM ThinkPad T20 Notebook
I have a laptop IBM thinkpad type 2373 I was trying to install a new OS, and I deleted all the partitions and format the hard drive, but the installation failed. And now I have been trying to start the...
Hi
You need to make the proper format, in order not to see this message.
Tell us please which OS you intend to install, what tool you used to format?
If your hard drive is 250 GB or less, you can format it using OnTrack Disk Manager,
For any hard disk capacity, you can use Windows CD to format.
Please tell us your results
Good Luck
May 14, 2011 | IBM ThinkPad T43 Notebook
I have problem to install window xp in my laptop, which already have window vista....my notebook donot support to install xp..please tell is there any way to install xp...
What is your problem specifically? Is it that there is no hard disk detected when you try to install windows xp?
Try using third party software to detect the hard disk on your laptop
Try this link. It will basically give you your hard drive driver while installing windows xp. You will also need an external floppy disk drive if you dont have diskette drive in your laptop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70477
Jan 24, 2010 | Computers & Internet
I loaded a new, Windows XP formatted IDE in a 570e-then nothing
Well the formatting must have been different! try dropping the partition and format using the pc you are installing it on
Sep 07, 2009 | IBM ThinkPad 570E Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
ThinkPad A21m won't boot into Windows
Did the laptop you got come at least with a windows XP cd? If so boot the laptop off of that and try to install Windows XP and see if it goes thru. Just make sure during the installation you tell it to delete the partitions first and then let it go thru that way you know for sure the hard drive is clean at that point.
Feb 02, 2009 | IBM ThinkPad A21m 2628 Notebook
Dual boot problem
xp can not recognized the sata hard drive u have to install sata drivers before installing xp.
Nov 19, 2008 | Toshiba Satellite A205-S4617 Notebook
I have problem when installing windows xp
are you install OS inside you notebook is windows xp profesional SP2???? because follow my information the rest of driver can istall just by the acer cd driver only driver display and wireless you nees to download from other link internet.
Jul 24, 2008 | Acer Aspire 4315 Notebook
MY IBM WILL NOT BOOT
bro just one good thing you should do... if you got no important files in the hard disk just clean format the drive and reinstall a good tested OS probably windows xp pro... make sure you low level format your drive before installing the OS... also you may try updating your BIOS.
rank me if this help ok...
Jan 19, 2008 | IBM NetVista PC Desktop
Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Oct 02, 2007 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
118 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
