This is a new Zoom ADSL 4-port Wireless-N Modem/Router X7N 5790 and once all the 'logging-in' procedure has been done there is still no wireless connection to my new Kindle Fire HD
SOURCE: Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem. solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99 ip address: 192.168.2.12 (static ip address for computer) subnetmask: 255.255.255.254 (generic subnetmask) default gateway: 192.168.2.1 (ip address of router)
SOURCE: Zoom X6 installation
hi i am trying to go in zoom x6 page and put the password for my internet coz we use share broad band. thanks
SOURCE: Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
ADSL Modem Settings to Wrt54g2 Router
Basic Wireless Settings
Wrt54g2 wireless security
Wrt54g2 firewall settings
