Question about Creative Labs MuVo Slim MP3 Player
Scroller only works 1/2 the time
I'm stuck in the music mode. I can use the scroll lever to move between tracks. However, when I go to the menu, the scroller doesn't let me move to any other option. It's on "skip folder." I can't move it right or left through the menu (to play mode, settings, mic, etc.) I reformatted the player - deleting all the files. I changed the battery. I turned it on and off. No quick fix seems to work. Any advice?
All u have to do is turn it of 4 a hour and turn it back on
Posted on Jan 25, 2008
SOURCE:
System error on xerox 8560dn 09 038 46 8515
ink count sensor flags are stuck.verify the ink is correct and genuine and then reset the error by doing the following
1- turn the printer on
2- wait for the xerox logo to begin moving acroos the display
3- Before the logo is centered on the display (stops moving) press and hold the back and help buttons on the control panel.
4- Hold both buttons untill the display reads beginning service mode initialization.Release the buttons and the printer reboots into service mode with the Service Diagnostics menu dislayed
scroll untill you find function menu then click ok
scroll untill you find Clear ISC fault and press ok
click back several times and then reboot the machine.
Good luck and let me know.
May 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Cannot stop shuffling
You need to go into your Play Mode ssettings and select "Repeat All" to turn off this feature:
Play mode
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
Mar 14, 2009 | Philips GoGear HDD1830 MP3 Player
Can't Get My Music Off My Tascam. I have a DP-01 portastudio and it has a usb connection but it's not being recognized by my computer. At first it just wasn't compatible with Vista now I have windows xp...
How to export your recorded tracks to WAV:
- Activate the Menu
- Scroll down to WAVE
- Press the right cursor key
- Go to Export Track
- Select the tracks using the Insert and cursor up and/or down keys
- Press Yes/Enter
- When the DP-01 is done repeat pressing Exit until the menu is closed.
Tascam USB mode:
- Press Menu
- Go to Disk
- Scroll down to USB OPN/CLS
- Press Yes/Enter
- Press Enter again to execute
- Press Yes/Enter again for the "Are you sure?" message
Now you will be in USB mode and you will be able to access the DP-01's hard drive and download the exported WAVE file(s).
Remember: the DP-01 will stay in USB mode until you remove the deviceusing the Safely Remove Hardware option in Vista and then press Exit onthe Tascam!
Oct 18, 2008 | Tascam DP01 All-In-One Recording Package...
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
Scroller jammed
The scroller only goes to number 3 for sound and when scrolled down to music it goes so fast and wont stop
Jun 02, 2008 | iRiver H10 MP3 Player
Non-responsive scroller
well you can try and take it apart and see if you can see anthing wrong with the buttons, or you can replace the front with a used one on ebay.
http://repair4player.org/disassembly_creative.html
Jan 16, 2008 | Creative Labs ZEN Vision:M Digital Media...
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
Repeat All ).
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
My Sansa E280 turns blue but no Sandisk screen comes up.
I'm SOOOOOOO excited i got it to work again. I took off the back cover and removed the battery while the scroller was on and blue, then right above the battery there is a black rectangle thing that was not flush with the rest of it. I pressed that in turned it on, and bam it was good to go. I hope you all have as good of luck as I have had. Let me know if it worked for you!
Oct 26, 2007 | SanDisk Sansa E280 MP3 Player
Sansa e260 has lost my songs and other problems
Sounds like the device may be full.
The device has 2 modes, if you put music on in either mode, you cannot see it in the other.
Easiest solution is to format the device and remove everything and then transfer them back in 1 specific mode.
To format in My Computer>Device Name (e260)>Right click and select format.
Best of Luck.
Oct 13, 2007 | SanDisk Sansa e260 MP3 Player
Creative Labs MuVo Slim MP3 Player Logo
43 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
