Question about Compaq FS7600 17" Flat Glass Monitor
Horizontal lines dark background Problem - Compaq FS7600 17" Flat-Glass Monitor
I am finding a Misty Foggy Appearance in my Color Monitor. I could see everything but with such appearance.
  • Anonymous Dec 24, 2007
    everything foggy colrs all green and red nothing lokks right
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
1 it is generally due to poor focusing. 2 check crt base for loose or focus control wire loose. 3 if monitor is very old then crt might be weak. good luck.
Posted on Oct 08, 2007
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Horizontal vertical lines on Laptop screen
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 04, 2012 | Lenovo IdeaPad Z560 Laptop Computer -...
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Incomplete text, every other line is messed up.
  • If the scanner glass or the white scan background (the white portion of the lid) are dirty, the scan might be different than intended. A dirty scanner glass (fingerprints or smudges) slows down performance by as much as half a minute and affects scan quality. Performance slows because the product is actually processing the smudges on the glass. Turn off the product , and then clean the glass with a soft cloth or sponge slightly moistened with a nonabrasive glass cleaner. If there are visible contaminants under the scanner glass, the product must be sent in for servicing. You cannot remove the scanner glass to clean inside.
  • Reinitialize the scanner by turning off the product and unplugging the power cord. Make sure that all original documents are removed from the product and that the scanner glass on the product is clean. When the power is reconnected and the product is turned on, the scanner recalibrates.
  • The computer video driver and video settings might change the image appearance slightly. The product scans in 24-bit color. Setting the video display settings to less than 24-bit, or 24 million colors, results in a loss of color information on the computer monitor. The video driver might change the appearance of colors when viewed on the monitor.
  • Jul 09, 2009 | HP Officejet 4315 All-in-One Printer
    Rolling Horizontal Lines across the screen
    ground loop is problem. Many answers available via Google.
    Jul 07, 2009 | Acer AL1916W 19" LCD Monitor
    Picture Problem
    In that set its usually a bad picture tube. The lines you are seeing are called retrace lines. You can take it to a shop and they may be able to rejuvenate the tube
    Mar 13, 2009 | Televison & Video
    Rolling horizontal line on screen
    What was the reason for aquiring a new monitor?
    Nov 23, 2008 | LG Computers & Internet
    LCD... Problem
    so I have the same problem. when you get the answer please send me an email with the info. I´ll do the same
    uguetoe@gmail.com
    Nov 25, 2007 | Gateway FPD1975 19" LCD Monitor
    Thin pale Horizontal line
    I tried this and it has worked temporarily by banging the monitor not great but it did work, no tech knowledge if there is any other advise please email.
    Hiyama Monitor Model: Vision Master 17 (8617E Chassis)
    Horizontal dark line across screen shadowing text or other complex display data - giving appearance of 3D grooves or just dark lines on light background - temp fix (few minutes) by banging monitor or jiggling the video cable (thats what threw me for a while)
    Removed tube base board and ran over disc capacitors and other solder joints whether they looked dry or not. No re-occurence in 2 weeks of daily use. Seems to have fixed it. (Be prepared for a lot of metalwork and screw removal when opening one of these up - I still havn't figured out how to get the PSU/main board out of one !)
    (John)
    Aug 20, 2007 | Gateway FPD1975 19" LCD Monitor
    Compaq FS7600 17" Flat Glass Monitor Logo
    101 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
