dear sir i m wark in repair and maintance company in UAE.i m fax technatian in this company.sir on problem in fax machine toner life end msg show on lcd.sir i change cartridge and complate drum but this problem is still.plz sir help me . thank you
-   i am working with brother fax-2820 machine, i have a problem that toner life end plz give me suggession to fix the problem -   Guest
Mar 01, 2008
-   my brother fax 2820 not printing one messege is comminig unable to print see trouble shooting and maintenance chapter in user guide help me thank you-   Guest
Make sure that you are not using generic supplies. Using generic supplies or supplies that have been refilled will cause the unit to give false errors. There is white piece of plastic inside the semi circular opening, if you do not see a white semi circular opening it is either a generic toner or starter toner and you will need to replace the toner with a authentic toner.
You may try this also: 1. Remove the drum and toner, separate the drum and toner and then rock the toner from side to side. 2 Put the drum and toner back together and clean the corona wire ten times.
3 Put the drum and toner back inside the machine and close the cover, if you still have toner life end try this:
a Open the front cover
b press the options key, the LCD will say "replace drum?"
c press the start key. and then press 10 on your dial pad. the display should say accepted for about 2 seconds and then say cover open.
d close the cover, if the display still has toner life end, you will need to replace the toner
